Question about Refrigerators
Problems with Frigidaire FRT18HB5DW0 Top Freezer Refrigerator
The problem started with the top freezer having froze built up inside, and bottom refrigerator was getting too warm. I shut down the power to the refrigerator, and tried to defroze the refrigerator for a day. When I tried to turn on the refrigerator again, the thermostat is silent and the compressor is not running.
Please advise.
Shao
  • 26 Answers
may be your thermostat is easy to cut off or not functioning ,pls check the thermostat .
Regards,
Edgz
Posted on Jan 27, 2008
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
FREEZER IS TO COLD, REFRIGERATOR TO WARM
if you can; find the vent(s) between the top and, bottom boxes (where the evaporator fan is located: closing these vents makes the freezer colder and, the refrigerator warmer, opening these vents the reverse is true.
Jul 19, 2010 | Frigidaire FRT17G4B Top Freezer...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
I have a top-mount Frigidaire Gallery frost-free freezer, and everything in the freezer and the freezer interior is covered with ice crystals. Suggestions?
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 24, 2009 | Frigidaire FRT15B3A Top Freezer...
It is very cold on the top freezer section but not cold at all in the lower refrigerator section
Sep 23, 2009 | Avanti FF511W Top Freezer Refrigerator
Freezer working: refrigerator not cooling
Sep 23, 2009 | Frigidaire GLRT83TES Top Freezer...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Amana refrigerator top freezer going out; water under crispers
you are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
Sep 24, 2008 | Refrigerators
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
