Question about SuperMicro SP352-TP Triple Redundant Power Supply Module (PWS-0026) (PWS0026B) 350-Watt Power Supply
SP352-TP power supply won't start
I have 2 TP352-TP s which won't start. The red LED is blinking only. The fault is in the ps. I tried running them only with a power connector, but i think there's any remote signal necessary to turn it on. So I'm actually looking for a disription for the big connector or maybe a schematics for the whole power supply repairing it.
For specialist only: When it's open and i connect the 12Vcc from the TOP223 to the PMW-IC 3844 it runs without any problems. I don't know which devices are connected between these points, maybe it's simply a resistor or so or any transistor what is switched by an extern remote control. Idk.
So if you have any ideas or hints, please let me know. I mailed to compuware.com.tw but without any sucess, no support from there. That's poor.
Btw, do you need any support for power supplies or any service? Don't hesitate and mail me: service@hoell-electronic.de
How do I fix my Sony TV?
Sir
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
DC_ALERT1 3
DC_ALERT2 4
DC_ALERT3 5
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
thanks
Sep 22, 2017 | Sony Televison & Video
SHARP LED TV does not power on
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 10, 2016 | Sharp Televison & Video
I have a pioneer PRO110-FD plasma tv with a 2 blink error code. What does the 2 blink error message mean
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 04, 2015 | Pioneer PRO-110FD 50 in. HDTV Plasma TV
Is the switch powered up ?
Faulty led of the switch generally glows when the hardware latched to it goes faulty such as fans and power supply. please check for LED in any of these. if you won.t find any LED in red in any of these then try to connect your switch through console port of the switch, if the out is coming as garbage value ie it is not asking for username and password the try to power off the switch ( your live services will go down running through that switch, so plan a MW for that) .
Aug 12, 2014 | HP ProCurve Switch 2510G-24 24-Port...
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
DX-PDP42-09 Won't power up. There is clicking for a few seconds, then led 2 starts blinking. The screen flickers and the red power light comes on. No picture, no sound. Which board do I need to...
Sir before replacing the board try to check first the power supply, this fault is commonly cause by bulging capacitor or leaky capacitor, this bad capacitor is producing a low and unfiltered dc output that causes your unit to malfunction.
This is the bulging capacitor if you see this replace with the same type and observe polarity, capacitor is much cheaper than the whole power supply board replace this and it will fix the problem hope this help good day and best regards.
Sep 21, 2011 | Televison & Video
The screen blinks constantly. I have checked all connections and they are tight but continues to blink.
Hi:
You have a fault either on the power supply or inverter board.. Check all caps on the PS and inverter for swollen capacitor tops.
Nov 11, 2010 | Insignia IS-LCDTV32 32 in. Television
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Feb 20, 2009 | Televison & Video
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Plug in,time will goby then it goes blank off, trys restrting
Sounds like The main power supply regulator section circuit fault. Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Apr 05, 2017 | Philips 32PF5320A 32 in. LCD Television
SuperMicro SP352-TP Triple Redundant Power Supply Module (PWS-0026) (PWS0026B) 350-Watt Power Supply Logo
62 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
