How to adjust white lines on screen
I have lines comming from the top of the screen going down about three to four inches on older tvs theres an adj. on the newer models do they have it or is it buit in if there is an adj on the board can u tell me where it is if not ill just take it to a tv service repair store
  • 107 Answers
It depends, sometimes this problem is caused by a capacitor around the crt socket or around the flyback and horizontal out.
or sometimes the signal reciever section..
Posted on Jan 27, 2008
  • Mark Payas
    Mark Payas Jan 30, 2008
    oh yeahh!!! did you adjust a variable resistor at the flyback or at the crt socket..? I just remember it... try it this way. but I'll advice you to do it with a pro. flyback is a highly voltage area same as the crt socket..
Emerson 32 inch lcd tv there is a pure white line 3 inches high on the bottom of the picture.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 28, 2016 | Emerson Televison & Video
My Vizio has three white lines running down the screen. Is there anyway I can fix this issue myself
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line fault to the most of the LCD TVs will be similar; irrespective of its brand name and screen size.
Feb 16, 2015 | Vizio Televison & Video
Just bought a 50 inch scepter and the top of the screen is blacked out in a swirl motion. Also there is a blue and purple line going down the middle of the screen. Can this be fixed or does it need to be...
Panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Jul 26, 2014 | Televison & Video
I have a 50 inch zenith plasma TV that has a three to four inch section across top of screen that is orange in color in full of lines
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Screen shots to defective Plasma TVs are given. You can see and compare it to that of your TVs' and can get an idea about the fault.
May 16, 2014 | Televison & Video
Imagerunner 2270 - When we make copies it is shifting the print down about a 1/4 inch. I think it is a calibration issue but not sure how to correct it.
Try making a copy directly on the glass with the top down. If this isn't correct then you have to go into service mode. Be careful of what things you highlight in this area because there could be problems after. Press the additional function key and then press the " 2 & 8 " keys at the same time, then the additional function key. If it doesn't work the first time press the reset key a couple of the times and start over. You should see something like copier, feeder, or fax depending on what configuration you have. Press COPIER, ADJUST ( across the top ), then ADJ-XY, ADJ-X ( this adjusts the image top to bottom ). ADJ-Y-DF adjusts the reading start position from the Document Feeder. Good luck.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
Hi i have a saville c90 projector and the 3 coloured screens do not line up so the picture is very poor.do you no how to realine them please
there are adjustments for "WHITE" and adj. for the separate colors. there is an adjustment door to open. make sure your screen is the right distance and is in focus. then adj the white controls to align screen geometry. then the rest is simple, the control has the screen geometry that it adjusts, showing you what it does.
Jan 10, 2010 | Televison & Video
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
