Question about Onkyo TX-SR500 Receiver
Onkyo TX-SR500 loosing settings
Hi guys,
my Onkyo TX-SR500 loose all the settings I make when it is off (not stand-by) for a week. This period is getting shorter. Is there anything I can fix? Is there any backup battery to be changed or so?
Thank you in advance
  • 1 more comment
  • Anonymous Oct 16, 2008
    I had a similar problem.When the power goes out the settings are lost.I now have another problem in regard to speaker balance.When the setting is adjusted and reciever left on stand by mode when turned back on it reverts back to old setting.
  • cooked1 Oct 16, 2008
    i had a similar problem when the power was lost.I now have another problem if i adjust settings turn reciever to stand by then turn it back on it reverts back to previous settings
  • david310572 Dec 06, 2008
    I have an Onkyo 601E A/V receiver which is suffering the same issue. The power is *not* swiched off but it is put into standby mode overnight. All the settings are lost from time to time. Turning the power to "off" at the switch does not cause a reset by itself. The time between these "resets" is also getting shorter.
    Problem Solver:
  • 18 Answers
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Posted on Jan 28, 2008
  • Nisei Aug 29, 2011
    I always turn off my TX-SR602 (not stand-by) and there have been times that it hasn't been turned on again for weeks (perhaps even more than a month). I can hardly believe that the power left in the capacitors would keep the settings for such a long period of time.
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
System lock
POWER YOUR AMP ON GO TO MENU SET UP AND AT THE BOTTOM OF THE LIST YOU WILL FIND SYSTEM LOCK ,TURN IT OFF.
Dec 16, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Standby light blinking -unit won't stay on
When it is on, does any audio come out of the speakers? If so, you may have a problem in the protection circuits. If no audio is heard, I would first check the speaker wires to make sure there are no strands shorting across the terminals, and that you have the it selected to output audio to the speakers -- Now also be sure to check the various inputs, for instance if it has a FM receiver, select that and see if any audio comes out then as well. I don't know what the cable guy could do other than knock loose a wire or change connections on you.
Jan 13, 2007 | Onkyo TX-SR500 Receiver
Onkyo TX-SR500 Receiver Logo
1,157 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
