Mapman DVD Player DVL 7
Hello.
Have you got the information to make my Mapan DVd player play Region 2 DVD`s instead of Region 1 ???
Regards
Michael Asprey
  • 86 Answers
SOURCE: Changing region on a DVD player
You did not specify what kind of DVD player this is? Since you said player, and not drive, then I will assume this is a dvd player you hook up to your TV, not install in a computer.
Simple answer, you can not change the region code on a DVD player, unless there is a known hack listed on a website.
Therefore, your only option, is get a region free dvd player. They are cheap and easy to get on amazon.
here is one for $30:
http://www.amazon.com/Philips-DVP642-DivX-Certified-Progressive-Scan-Player/dp/B000204SWE/ref=pd_sim_e?ie=UTF8&qid=1196024533&sr=8-9
Posted on Nov 25, 2007
shaggyrat
  • 1224 Answers
SOURCE: hello i need help lol
you gotta open the disk tray and then run the code
Posted on May 28, 2008
jaffa012001
  • 376 Answers
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Posted on Aug 12, 2008
Geekman
  • 32281 Answers
SOURCE: unlocking DVD rom to multi-region TS-L632D
You can change the DVD region four times only, the fourth change will lock on that region permanently.
There may be a firmware upgrade that make your DVD region free, but if you make a mistake or install the wrong firmware upgrade then the DVD will be a piece of junk. You will need to Google search for DVD firmware upgrades for your model DVD.
The best way to view DVDs from other regions is to install a piece of software that defeats the region code. I use a program called DVD-RegionFree from
www.dvdidle.com
There are possibly other programs available, again Google search for them.
Posted on Jan 22, 2009
Beignorant
  • 51 Answers
SOURCE: multi region code for GPX PDL 705 portable DVD player
I hope this helps^^ try it and gimme a shout!
Turn on power.
Open lid.
Push 9 7 3 5 from the remote.
Select 0 using arrow keys.
Exit Setup.
Done.
The one above did work me, only that after one turns on the player, enter in the 9735 with the remote and press 'enter', you can choose between making your player region-free or a different region in addition to R1. Select the desired region unlock and press 'enter'.
Make sure you check the bottom of the DVD player to see if it was manufactured in the first quarter of 2007, that might factor in whether the code can work or not.
Posted on Apr 01, 2009
Region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
Convert US DVD in Region 1 to play in UK Region 2
Please go to codemasters.com , type in the details of your dvd player, there will be several region code hacks ,follow the instructions and this should work for you, basically you are needing to make your dvd player a multiregion player. all dvd players are multi region at time of manufacture, but they are code set for the county that they are shipped to, hopefully this should help. you can also go on to google type in Hack for whaterver your dvd player is and you will get a region code there.
best Wishes
jimba
May 28, 2009 | Philips Televison & Video
DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Apr 22, 2009 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlocking procedure for the samsung dvd-p181
Pls try:
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Televison & Video
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
I am in NZ and have philips 616K dvd player. Have some dvd's origin UK that wont play on my dvd. Comes up wrong region. My daughter also in NZ has played these dvds in NZ but not sure what brand dvd she...
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', 'l' in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
Jun 28, 2008 | Televison & Video
I need to change the region code to allow region one play on my Samsung 5124 DvD player
Sumsung usually has letters before the numbers.Would you check the model # at the back of the player for this
It could be something like DVD-D5124 or DVD-S5124, etc.
And do you know what region you are currently set for?
Since you may have DVD-S124 try this solution to become region free. It is quite convoluted, but most of these are so you may want to copy this and paste into Notepad or any writer program so you can save and print a copy.
[from videohelp.com]
1.)Leave disc tray empty.
2.)Power up player.
3.)Press Play and Stop on player simultaneously for around 3 sec.
Language screen should appear.
4.)Press "repeat" on remote, then 76884
5.)Press 9 for region free player.
6.)Press the open button on player.
7.)After 15 sec Press "Power/Standby on remote.
You should now be region free.
Regards,
Worldvet
Jun 12, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
 Grubhead
Grubhead
