Question about Fujitsu Siemens Pocket Loox N520 Pocket PC
PDA now doesn't pickup GPS satellites;when it did I couldn't access map charting software
Intergral GPS is set to use COM 8 port for hardware connection and COM1 port to talk to other programs, using COM 1 and having tried several other alternatives, unable to get navigation charts to pick up GPS signal, error code: Communication Timeout.
PDA settings are NMEA 0183, Baud Rate 4800 in accordance with PDA handbook and chart software instructions. Unable to confirm COM8 was factory setting but other than that, what am I doing wrong?
  • 5 more comments
  • pobble Jan 27, 2008
    Changing the Baud rate to 57600, and several other rates tried too, hasn't resolved the problem.
    I'm guessing but I reckon it's either because I've altered the Com port settings for programme and hardware or there has been a hardware failuer of the integral gps device. Since this worked previously and I don't have much belief in concidences I am sceptical of that idea
    Further observation which leads me to think the Com port settings are the culprit.
    ......Just tried to connect the charting software to the GPS locator(even though it had no satellite fix) and I get a screen warning which says" unable to open Comport ,check that no ther device is using the GPS" it thenm directs me to the IR setting which shares the same Com port-- the ' all beam accept' check box is empty and I have no other software using the gps, so even more puzzled.
    Therre are clearly two issues here.
    1. what has changed to cause the GPS locator to fail
    2. What must I do to the settings for the charting software, to let it connect to the received gps signal
    tried Com ports 1:4- no good
    also 4:1- also no good
    BUT returned to Com port 1 for gps hardware and back to Com 8 for interface THEN did your suggested 'soft' reset.
    The GPS locator immediately showed satellites it was trying to lock on to- I suspect this hardware is very basic as it showed only three weak signall stats. whereas my handheld Garmin, alongside it shows 8 very strong signals- so this device may never be satisfactory- but at least it is working.
    However, issue #2 - of connecting the mapping software continues to be a problem.
    If I switch the locator off, then activate the chartware( the pda has only a small amount of RAM) I get " communication timeout.
    If I leave the locator on,in the background, the same message comes up.
    In both cases when I check the Settings from the main Windows Mobile screen, I find that there is a message on the GPS menu screen telling me that the Com port can't be opened and to check if another device is using- which is not the case.
    The chart software setup drop-down menu also tells me that a 'communication timeout' has occurred(with gps locator running or off). Also I get a message that 'Com port #' unable to open"0
    By the way my pda has SiRF device and I've tried altering the setting from NMEA to SiRF without success
    Since resetting and recovering the gps locator, as above, I've tried the earlier suggestion of a 57600 Baud rate but no good.
    The
    No facility to do so, so far as I can tell, and Com 1 is for the now working gps hardware, so expect you meant Com8 but the same applies
    Yes, I reckon you are correct in your suspicions but I have checked out, or so I think, those elements you mention and I cannot see any conflicts.
    No other software is using the same Com port as far as I can see, at least in gps terms. No other application is open at the same time as the mapping software/gps locator- so I think I'm at the fullest extent of my competence- which isn't saying much!
    I shall make renewed efforts in the week ahead and try any other ideas that come to mind and if, by some chance, I find a solution I shall so inform you.
    May I take the opportunity now, in case my return is not worthwhile, to thank you for efforts- I am much obliged.
    Best wishes
    Gordon
  • pobble Jan 28, 2008
    I'm unable to identify a manual port on either the pda or the charting software, so maybe that isn't an option on this device?
  • pobble Feb 02, 2008
    Yes, it is impressively short on technical stuff, including setup, defaults settings etc !
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Select a manual port to com1.
Posted on Jan 27, 2008
  • 1 more comment
  • Anonymous Jan 28, 2008
    selecting the manual port may get it work.
  • Anonymous Jan 31, 2008
    well did u check the manual?
  • Anonymous Feb 03, 2008
    well u didnt mentioned about the manual do have 1?
  • 2,427 Answers
Set Baud to 57600
  • Rishi Roshan Ali Jan 27, 2008
    did you try resetting it ?
    if that did not help try setting your gps to com 1 and the iunterfce to com 4
    or vice versa
    check your settings in the mapping software
    see if your settings seletcted com port is set the the same comports you have set..
    also look at your different connectivity options,, LIKE infered , blue tooth etc. and make sure it isnt the same com port that your mapping software needs to be used, you can try disabling differerent connection types ..
    But basically what is happeneing is that the port the app is set to, isnt open or is being used by something else..
    Try those and let me know what happens
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Posted on Nov 22, 2007
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
No valid GPS signal for two days, what I can do?
You can try a reset Check in the manual where the reset hole is i thinlk this model is under the scfreen surround which is removable.
This will take ut back to factory settings, you might want to check if its set to the right PORT and BAUD try this
GPS Program Port: COM1
GPS Hardware Port: COM9
Baud Rate: 4880
Manage GPS Automatically (Ticked)
Now other reasons are low battery= low signal//fully charge the battery
no signal from satellites= damaged SIIRF chip caused by plugging into car power when starting engine...needs new m/board
Maximum time to access 1-9 minutes max...
Please rate my help++++Thanks for using FIXYA...
Dec 01, 2009 | Tomtom ONE GPS Receiver
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
My Dell PowerEdge 2500 has 2 configurable com ports which are setup as Com1 IRQ-4, and Com2 IRQ-3. My problem is that everything seems to say that they are there and active, but my software only can talk...
That "in-op" COM port is in fact, probably defective. Had many cases where 1 works/1 doesn't. Buy a cheap, PCI COM port board, install the software, and plug away!
Cheers,
gurutim
Mar 19, 2009 | Dell PowerEdge 2500 Server
Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Dec 11, 2008 | Epson TM-U220PD Matrix Printer
Garmin GPS III Pilot to PC communication problem
If it were doing this just on the Vista machine I would say it was Vista related but since you are getting it from an xp machine as well the problem is either cable or the gps unit. You don;t say if this just started happening or ? If you can try out the cable on something else to make sure so you can eliminate it. About the only thing you can do is to make sure the port settings in the pilot are set correctly. Generally the slower the better if you are having communication problems as this makes the signal timing not as critical. Try 9600 baud to start. Make sure that the data bits are also set roght. This is the 8n1 or 7n1 thing you see. I can;t think of what the default is on the garmin but as long as both pc and garmin have speed, bits, parity, and stop but set the same they should talk.
Try to download from the unit as well as upload.Unfortunetly you can only change the speed and protocal or reset the unit. You won't be able to fix it if is a hardware thing. If you are using a USB to Serial adapter then I would say that is your problem or could be. Cheaper ones just don't work often on higher port speeds. You might want to try the gps on a pc with a actual serial port if you are using one. If it works then you should try a different brand of adapter or really slow down the speeds.
This won;t solve it unless you luck out but it should let you know where the problem is.
Dave
Jul 10, 2008 | Garmin GPS III
Refuses to print in XP - no error messages
Try going to 'add & remove hardware'. Remove the COM ports. Reboot your computer. Windows should find your hardware and install the COM ports. If not, add the COM ports manually. Leave the printer COM port settings on COM port 1 or COM port 2, whichever you prefer.
Jun 24, 2008 | Datamax Prodigy Plus Thermal Printer
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
Console cable pin out?
I don't know the Netperformer but several console cables are listed on AllPinouts (http://www.allpinouts.org).
AllPinouts is a Web-based free content project (like Wikipedia) that collects information about hardware interfaces of modern and obsolete hardware, including pinouts of ports, expansion slots, and other connectors of computers and different digital devices (i.e. Cellular Phones, GPS, PDA, Game Consoles, etc.). All text is available under the GNU Free Documentation License (GFDL) and may be distributed or linked accordingly. AllPinouts archive already contains hundreds of pages organized into three main categories (Connectors, Cables, Adapters) and several subcategories.
Oct 10, 2007 | Lucent ACT Netperformer 9360 Multiplexer...
Fujitsu Siemens Pocket Loox N520 Pocket PC Logo
574 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
