Question about Mag Innovision LT776s 17" LCD Monitor
I Can't locate power recepticle
Where is power receptacle for MAG Innovision LT776 model 780?
Thanks!
Barry
  • barrymake2 Jan 30, 2008
    Well that is what I thought. There is a panel on the back 3 - 4 " in length facing down.
    The video cable for the monitor comes out the monitor on one side, but the 3 - 4 " panel is solid all the way across. There is not a receptacle there???!!!
    Any other ideas?
    Thanks!
    Barry
    President:
  • 1,950 Answers
It's on the back facing downwards.
Posted on Jan 27, 2008
  • Damen Wong
    Damen Wong Jan 30, 2008
    The monitor should be sitting on a hinge. Did you look behind/under it?
  • Damen Wong
    Are you sure the panel can't be removed (did you check that it doesn't have some kind of mechanism that releases it)?
6ya staff
SOURCE:
Tip
Setup Menu for MAG LT776 Model 780
I had a blank screen and went through the Setup tips here (in the blind) only to discover it was 3 bad caps on the PCB. I replaced them (tight fit) with more low-profile ones. They were swollen only, not burst or leaking. I put new 220uf 16V ones in, got my screen back.
I realized that it would be helpful if there were an image available for anyone troubleshooting, especially if not familiar with this model, or it's setup. I made the following image, maybe it will help someone in the future.
I see the image is resized for the forum, here is a link to a full size (700 x 850) viewing.
Full size Setup Screen
on Jul 17, 2011 | Mag Innovision LT776s 17" LCD Monitor
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I bought a mag innovision model 780 monitor at a garage sale to use with my ACER mini laptop. This monitor has a manufacture date of January 2003 - it did not come with a power supply. Where is the power...
With Most Mag monitors, the plug is a simple 3 prong on the bottom side of the monitor. Though it isn't proprietary, it isn't a common power plug either. Radio Shack does carry this type of cord. Just look on the bottom side of the monitor itself. the three round plug "thingy" is where the 110v plugs in straight from the wall. Best of Luck!
Feb 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
141 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Thomas F. Schneider
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
