Question about Foxconn K7S741GXMG-6L Motherboard
FOXCONN K7S741GXMG-6L Hi, WONDER IF YOU COULD ADVISE ME ON A FAULT. PUT IN AMD 2800+ PROCESSOR IN ABOVE BOARD TO TEST ITS OPERATION, BOARD WORKED FINE. REFITTED THE ORIGINAL AMD DURON 1200Mhz PROCESSOR NOW THE BOARD WILL NOT BOOT AT ALL, TRIED NEW MEMORY STILL NO GO, CAN YOU SUGGEST ANYTHING PLEASE ?
  • 1 more comment
  • brookmotor Jan 27, 2008
    Hi Lemmar,
    Thanks, could you answer why we were running the Duron for months before I messed things up ??
    brookmotor
  • brookmotor Jan 28, 2008
    Hi Lemmar,
    Thanks again, tried the bios switch, still not getting boot, looking grim ?
    Wonder if the board won't let me go backwards in processor !!!
    Any more advice ?
    Greg
    PS Thinking of connecting a speaker to get any error codes ?
    Hi Lemmor,
    Any more advice ?
    Greg
  • 749 Answers
AMD 2800+ is 333MHZ while
AMD DURON 120MHZ is just 200 MHZ
It means that the board supports 333MHZ not 200MHZ.
Well it's not compatible...
Posted on Jan 27, 2008
  • Rommel Balcita Jan 28, 2008
    Well, if it works before.. you need to RESET the BIOS in order to remove the AMD2800+ that had been detected during the test operation.
    While computer is off. Replace the 2800+ and place the 1200 processor.
    On your motherboard, find the jumper 1 (JP1) always near to a button cell.
    Remember its original position, remove and place it on the next pin, this will erase the bios... just like that, now put it back on the original place....
    Check all connection, make sure everything is right.
    Now test the computer with the 1200MHZ processor...
    Now the BIOS needs to be reconfigured or to set the date and time right.
    good luck
1 beep then shuts off
Hmmm, one beep is good! lol!
Means P.O.S.T. is good.
http://www.newegg.com/product/product.aspx?Item=N82E16813186029
I see we're working with an AMD processor, and a Socket 462 (Socket A), motherboard.
Let's look at some basic installation problems for that motherboard, and see if any fit;
1) Since it is an AMD processor motherboard, you have to be SURE that Thermal Paste has been applied PROPERLY, and applied.
http://www.hardwaresecrets.com/article/274
An AMD processor runs hot, for the models that fit that motherboard.
If no Thermal Paste has been applied, the AMD processor could have burned up.
2) Anti-Static Precautions:
I know, I know. But you would be surprised with those of us, who do not know what Anti-Static Precautions are; and work on computers.
(Hmmm, wonder why it doesn't work? Must be a bad motherboard)
3) Mounting to the Support Plate.
The Support Plate can be a separate metal plate; or is part of the computer case.
Mounting of the motherboard to Support Plate can be done with plastic Spacers; or metal Standoff's.
(Standoff. Shapes vary a little, but basically; 3/8ths to 1/2 inch long, hex shaped, threaded shaft on one end; and a threaded hole on the other end)
If a Standoff is NOT mounted to a motherboard mounting hole; and is just sitting out there on the Support Plate; it can touch exposed solder joints on the bottom of the motherboard, and cause a Short Circuit.
MOST of the time if the 'offending' Standoff is removed; or placed where it should be, (Motherboard mounting hole), then the motherboard, etc may be OK.
4) Power Supply:
If the Power Supply was on it's last leg, this may be the 'straw that broke the camel's back'. Power Supply went to the Power Supply graveyard in the sky.
If the Power Supply does not have enough power (Wattage, and Amp's), then you would also see the problem you stated.
New Power Supply, or old? What is the manufacturer, and model number?
Post back in a Comment.
What AMD Socket 462 (Socket A) processor did you install?
What Ram Memory?
How many optical drives? (CD/DVD drive)
How many fans?
Regards,
joecoolvette
Dec 27, 2012 | Foxconn K7S741GXMG-6L S.462 Motherboard
Please could you advise me if i can get a compatable dual core proccesor for my Foxconn 661M03-G motherboard Motherboard ID 05/26/2006-SiS-661-6A7I4FK9C-00 please would you recomend a proccesor that will...
Sorry but that motherboard does not support dual core processors. The socket type is 478 which is Pentimum 4 and will support anything up to a 3.2 GHz processor.
Regards.
Jan 05, 2011 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Post issue
I can't get Foxconn's website to pull up ATM, but I had this sort of issue once before, and felt completely stupid once I figured it out, and this is going to sound strange, but, remove your CPU fan and try to power up. If it does power up, then your CPU Fan is shorting out the system. If that doesn't fix it, then it is possible that your processor is not supported by the motherboard.
Hope this helps!
-Backu
Jan 15, 2008 | Foxconn K7S741GXMG-6L Socket...
Bios and ddr
The new RAM is faulty or incompatible.
Take out the old RAM and see if the error goes away. If it does the two sticks are incompatible. If not the new RAM is the wrong type or faulty.
Get a stick that matches what you have, and you should be OK.
try  www.crucial.com and use their memory finder.
Oct 15, 2007 | Foxconn K7S741GXMG-6L AMD Socket A Athlon/...
Foxconn K7S741GXMG-6L Sound issues
maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Jan 26, 2007 | Foxconn K7S741GXMG-6L Motherboard
Dead board.
He is refering to this posting: http://www.fixya.com/support/t128900-mobo_no_boot_after_changed_power_supply
Jan 01, 2007 | Foxconn K7S741GXMG-6L Motherboard
Foxconn K7S741GXMG-6L Motherboard Logo
165 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
