Question about D-Link AirPlus DI-524 Wireless Router
Router rebooting? This is a weird one. The router is losing the ppoe connection (earthlink dsl) and apparently resetting itself at random intervals. Anybody? I have the latest firmware (4.03) The reason I think it is rebooting is that I lose the local area connection (says cable is unplugged), and then windows (XP SP2) goes through the whole process of acquiring a new ip address. I am not losing the connection at the dsl modem. This happens on either wireless or wired connections. I am stumped here. Could I have some kind of hardware failure? (I realize that it is an old model router .....)
  • Terry Jan 27, 2008
    power adapter is connected nicely
    no heat problems
    don't have a ups
    Its not a power issue, as I am not losing power at all.
    The router just seems to be resetting itself. It appears to be a usage issue of some sort, because as long as I am doing just basic web browsing, the problem is not so bad, but when I try anything else (mail on port 25, ftp, anything involving torrents, certain IM clients), it is horrible.
    It is almost acting as if there is something that is triggered when activity on any port other than 80 happens, and that is causing the router to reset itself ........
    It is driving me crazy!
BTW router firmware 1.04 is stable, but 1.05 seems to cause restarting of the connection as well.
Posted on Apr 26, 2008
  • 34 Answers
Try the following...
  1. Is your Power adaptor is loosely connected to the power socket?
  2. Check is the power adaptor produces more heat?
  3. Try to connect the device to the UPS if not..
If these are not the issue then there is possiblity of device failure.
Posted on Jan 27, 2008
  • Vijayakumar TP
    Vijayakumar TP Jan 27, 2008
    If that is the case just try enabling firewall if not enabled. Just allow only the required port.
    If your device password is default pls change something else.
    Please disable the SNMP Setting if enabled.
    Please try them and observe.
  • Vijayakumar TP
    you can find the document at the below location.
    http://www.dlink.com/products/support.as...
Zoom X7n Dsl 2/2 Modem/router/gw dsl light blinks constantly when trying to connect to Earthlink
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Nov 18, 2013 | Zoom X7n Dsl 2/2 Modem/router/gw
Zoom X7n Dsl 2/2 Modem/router/gw DSL light will not stop blinking - trying to connect with Earthlink
Earthlink is not your local telephone company? You would need to contact your local service provider. If earthlink set up your DSL thru your local telephone company, you may have to have them contact them. Does your local phone to you or do you subscribe thru what they call a CLEC?
I cannot connect to the internet with my linksys wireless router hooked up through my dsl modem. I also lost the installation disk. What can I do to resolve my problems?
DSL uses a ppoe account. Your DSL provider should have given you a router/dsl modem to connect to the internet, and then you can use another router to feed the house a wireless connection. The ppoe user name and password should be set up on one of these devices. If you don't know what your user name and password is, (I forgot mine a long time ago), you can contact your provider and have your password reset. Once this is done, you will either have to connect via wire to the device that should have your user name and password, and set it. Default IP address to get into this router is 192.168.1.1, type that into your address bar on your browser.
default user name and password are both admin, all lower case for both.
Once you get into the device then you can go into the setting and look for connection settings.
Here is the PDF for this router. Start looking at page 5 to learn how to set up a ppoe user and password.
http://www.quickline.com/Shop/Documents/Benutzerhandbuch_WRT160N.pdf
Dec 30, 2010 | Linksys WRT160N Wireless Router
My isp att give me a ppoe on dsl i use a di 524 router my probleme is i need to put my local connection on 192.168.1.100 to 192.168.1.106 if i try to une ppoe on the router with the lan to 192.168.1.1...
try opening the router with 192.168.0.1, or 192.168.1.2
one of those should allow you access to your router...you will still have to enter any password that you have set up for it, but it should at least get you to the " front door "
Dec 15, 2010 | D-Link AirPlus DI-524 Wireless Router
Wireless computers lose signal
try reset wireless settings
or reset to defaults and use a wpa2 Encript security.
Jan 15, 2010 | NetGear WGT624 Wireless Router
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses 192.168.1.1. You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
Nov 05, 2007 | Belkin (F5D8231-4) Wireless Router...
DSL LINE IS NOT CONNECTING
Assuming you have set all your ISP's connection details correctly eg PPOE or PPOA, VC-MUX etc, double check you username and password, check your adsl filter and check there is no line noise on the phone line. It could be that the router needs reseting by way of a small reset hole at the rear of the router or it may well be that your ISP's server is down.
May 02, 2007 | Zyxel Prestige 660H Router
D-Link AirPlus DI-524 Wireless Router Logo
119 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
