Question about Casio Exilim EX-S500 Digital Camera
Compact digital camera lens assembly jammed after dropping
Dropped a Casio Exilim EX-S500, and the lens assembly is now stuck open (extended) and slightly crooked (downward). Repair is more than the camera, and maybe unsuccessful. Should I just try to pry it back?
I worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Posted on Mar 24, 2010
SOURCE:
Where can i buy the lens barrel for my Casio Exilim EX-S500 cam? i dropped it and it was totally damaged
you did not indicate where you live so I am assuming you are in Canada.
Here is the support line for Casio.They should have all the replacement parts also, they should be able to let you know if there is a repair shop close to you.
http://www.casio.com/support/authorizedservice/
I hope this is of help.
Nov 28, 2009 | Casio Exilim EX-S500 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Ex s500 - camera lens stuck in out position.
Sounds like you have a defective motherboard, because it wasn't dropped, it is not usually a lens issue. This is a camera repair place, they specialize on small cameras like casio exilims. I've had a Canon sd750 fixed with them for the exact same problem. The website is : camera repair nyc
Jan 03, 2009 | Casio Exilim EX-S500 Digital Camera
Casio camera lens stuck
I fix digital cameras call 214-650-6531 or email me at mike@digitalcamrepair.com
Feb 06, 2008 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX1050 10.1 Megapixels
Remove the screws/case and with power on, slightly push the lens back
make sure you disable the play mode so it not turn on by itself if you accident touch the play mode
hope this help
Nov 20, 2007 | Casio Exilim EX-S500 Digital Camera
Camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Feb 13, 2007 | Casio Exilim EX-S500 Digital Camera
EX-S500 Casio Exilim - Lens does not full extend on camera so the picture is blurr
get the new ex-600s.. my 500s's lens wont come back in either.. i got the 2 year ultra warantee this time cause they're junk cameras but it's the best compact for about a year till it breaks
Nov 12, 2006 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
495 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
