Question about Leadtek WinFast PVR2000 Video Capture
TV Tuner viewing
When I use my tv tuner, I cannot see the screen when navigating websites. I was wondering if there is a way to adjust the settings so that the 'tv tuner screen' is always at the front of the screen on top of any webpages.
P.S. I know I could adjust the size of the webpage but having the tv at the front is much more convenient
When running TV, click anywhere on it's screen, this will produce a 'drop-down window' within screen.
You can select the "Always on TOP" option.
You can also grab BORDER, with mouse, to resize it to whatever size you want.
Posted on Sep 09, 2008
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like, to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
My kdl55nx810 screen is blinking. While watching TV, the screen will go black for about 2 seconds, then come back on. It appears to happen intermittenly, every 15, 30, or 60 seconds. TV was working fine,...
This problems,it can't be repair.The tv Tuner signal board is problems and the the causes.The tv Tuner signal board have intermittent problems.That the board,where the tv incomming signal cable plug into it.Tv is still useable wright?Use it the tv as is.Or only way to repair it is to do a replacement of the whole tv Tuner signal board to fix this problems.Tries websites like, to buy a refurbish tv Tuner signal board for the replacement.
Mar 15, 2011 | Sony Kdl-55hx701 54.6 in. HDTV LCD TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Screen just went GREEN in middle of a broadcast. Tried settings, & then unplugged for 2 hrs. Still green screen.
The tv Tuner signal board is the causes and the problems.Tries websites like to buy a refurbish tv Tuner sisgnal board for the replacement.
Dec 17, 2010 | Sylvania LC420SS8 LCD TV
Picture is narrow, both sides of the screen. tried adjusting using remote. no joy.
Go to menu Picture.Go down the menu.Reset the tv back to factory setting,should solved ur problems.Not,than ur Tuner signal board,have problems,must replaced.Tries websites to buy a refurbish Tuner signal board.
Apr 10, 2010 | LG 42LC2D 42 in. LCD HDTV
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
Mar 18, 2009 | Compaq Computers & Internet
Want solution
well i think pixel view also provides this option of tv composite!! u need to check its property and check for an online support for this thing ,go to intex website and look for its property then its good to do anything,but i dont think that pixel view doesnt give default as well,because for the composite thing u need different type of cables for different type of inputs!! so when it comes to pc most of the manufactrers prefer tv tunning by default!!if u want read this article
hope i was of any help!!!thanx
Jan 29, 2008 | Computers & Internet
Dual toner card
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
When you watch TV with a Cable Box or a Dish Network Box you are using a tuner inside that box. The signal that comes out of that box only contains one channel, the one you're tuned to. So you can take the output of the Dish Box and send it into your ATI tuner card, but you cannot change the channel to anything other than what the DIsh Box is set to. I'm sorry, but that's just the way it is. I use a Hauppague tuner card that has what's called an "IR Blaster". By hooking this device up to my Cable Box and I can used my computer to change the channel on the Cable Box itself.
If you had cable, you could run the cable into the TV tuner and watch the analog channels. I have Time Warner in my area and they still broadcast about 50 channels in analog. I cannot use the tuner card to watch any of the digital channels. This probably does not help you, but I thought you might like to know.
I want you to know that I don't get paid to offer these suggestions. I know it's a strange hobby, but I like to help when I can. Even though I cannot solve your problem I hope I provided helpful information and you will give this solution a positive rating. I've noticed that many times this type of question goes unanswered because nobody wants to get a bad rating when a problem has no solution. Thanks and good luck.
Jan 02, 2008 | ATI TV Wonder 650 (DNH100715331) Video...
Leadtek WinFast PVR2000 Video Capture Logo
150 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
