Question about Archos 605 WiFi Digital Media Player
Screen not turning on.
Initial charge completed as per instruction manual (until charge light blinks). When device is swicthed on the green power light is illuminated but the screen stays as in the 'off' status. I can hear the disk running and have connected to the pc via usb.
  • Anonymous Mar 22, 2014
    when I plug into computer to charge the re light is blinking fast and a bit dim
    Problem Solver:
  • 7 Answers
Hold the power buton for 20s so it will restart
Posted on Feb 05, 2008
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
After unit has been charged for a couple of hours, the meter indicator light, as per the manual, is suposed to start blinking. Mine never has blinked.
I have several of these units and their lights have never blinked either. Just charge it until the green light comes on and that should be sufficient.
Oct 20, 2010 | Vector 1 Million Power Series Spotlight &...
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
Initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Phone blinks once and turns off
did you follow the charging instructions or did you start using it right away, because its very possible if you ignored the initial charging instructions that you could have ruined the battery from the get go. which would explain all the symptoms you listed
Dec 06, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Archos 605 WiFi Digital Media Player Logo
148 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
