Question about Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard
Gigabyte GA-8IPEI000 pro-g DDR2?
Hi, I am wondering if the Gigabyte GA-8IPEI000 pro-g supports 400mz pc3200 ddr2 ram? I noticed it say ddr1 ddr2 by the ram slots.
  • diamond3 Jan 27, 2008
    Hi, thank you for the reply.
    It is revision 3.1
  • Anonymous May 11, 2010
    What revision of the board is this? there are 4 revisions.
    President:
  • 2,351 Answers
Sorry your board does not support DDR2 memory. The dimm slots that you mention above are only showing you which slot is number one & number two. This does not mean the memory is DDR2. See your spec's at this link.
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=1759
Posted on Jan 27, 2008
6ya staff
SOURCE:
Motherboard gigabyte intel 875/865/848p ver 1.03 , whichtype of ram can i use (ddr1, ddr2, ddr3)?
Hello treutemo,
Welcome, and thank you for using FixYa!
To answer your question, it uses DDR memory. You refer to it as ddr1. It can handle up to 4GB of PC3200 DDR 400Mhz. RAM
have a great day!
Sep 11, 2011 | Intel Motherboard
Does gigabyte7vm33mrz support DDR2 RAM? MY MOTHERBOARD (gigabyte7vm33mrz) SUPPORT DDR1 RAM .CAN i CHANGE IT WITH DDR2 RAM.IS IT POSSIBLE?
Not. your motherboard support only DDR1 memory RAM.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 25, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Will my Gigabyte GA-8I915P Duo Pro Motherboard take ddr3 and ddr2memory upgrades
This motherboard can take a DDR2 RAM , this are the supported RAM for it Dual Channel DDRII 533 / 400 or Dual Channel DDR 400 / 333.
Feb 11, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
I want to know what type of RAM my RZ 81845gvm-rz supports is it DDR1 or DDR2
This page has the specs for the board. It has two slots for DDR266 or DDR333 RAM, up to 2GB.
Dec 10, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Can i use ddr2 ram in my pc inplace od ddr1 i cn purchase pc 07?
Hey there, Check for the slots given on your motherboard, whether all the slots are same; However a motherboard can support only one type of module either DDR1 or DDR2. your motherboard has only DDR1 slots. You cannot upgrade DDR1 to DDR2 cause the Memory Module or notches are different than eachother. Gimme Acknowladgement by rating me. Thanx - Romy Decostza
Jun 09, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
GA-81915PM manual Problem
Hi
Have you tried to run the scan on crucial.com ?? This will tell you exactly what you need with no room for error - I have used it on note books - laptops and desk tops worked every time - their prices are really good as well
May 03, 2009 | Microsoft Windows XP Media Center Edition...
Please help
The reason you are getting the beeps is because your computer has found Hardware problems. Different amounts and length of beeps mean different things. Laptops are different from Desktops so i cant tell you what it is but its most likely to be the RAM since you tried to change it.
When changing RAM: Not all ram is the same
1. Locate the original Ram. Does it Say DDR1 or DDR2. Make sure you get the same!
2. The Speed of the ram
PC66=66MHz SD Ram
PC133=133MHz SD Ram
PC1600=200MHZ DDR2
PC2100=266MHz DDR2
PC2700=333MHZ DDR2
PC3200=400MHz DDR2
PC3500=533MHz DDR2
PC5300=667Mhz DDR2
PC6400=800MHz DDR2
PC8500=1066MHz DDR2
Make sure both ram have the same specs and try to make it the same as the original stick.
When changing Hardware, be careful of Electro Static Discharge. Touch something metal like your computer case or a aluminum kitchen sink. Then static stored in your body may destroy the ram or your Laptop.
Oct 07, 2008 | Computers & Internet
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
200 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Ekse
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
