Question about HTC Touch P3450 Smartphone
How can i connect to antenna to get better perception at indoors?
Some times i will get a problem with signal, can i connect to antenna to get good network?
  • drsridhu Jan 27, 2008
    i dont know the options, i have seen the antenna option in the mannual. can i connect through blue tooth? plz give me both options to connect to antenna to get good signal. because when i am in my operation theatre, i am unable to get good signal, if i come out and top of the building, i can able to get the signal. suggest me the good one where can i get the antenna?
How r u trying to connect
1 by bluetooth or
2 by usb cable
Posted on Jan 27, 2008
  • Anonymous Jan 27, 2008
    try with the cable connection with anteena
    jala_sudhir@rediffmail.com
Problem with HDTV POWERED FUTURA ANTENNA 24769. Amp light goes out when connecting cable to amp. No difference in picture quality or quantity.
Well I think you are trying get a better picture not a better stereo signal unless TV tuner is in AMP. If not try connecting it to TV dirctly but first inquire manual to make sure that is how it is sappose to be connected. But if I was a betting man thats probley what it is, but not sure what equipment your working with besides the info on atenna that you sent.. Good Luck !
Apr 15, 2014 | GE 24769 Futura HDTV Indoor/Outdoor...
What kind of indoor/outdoor antenna I need to purchase for this TV? What specification do I need to look for?
Hello
An outdoor antenna is more better than indoor antenna. If we fix an indoor antenna, especially in rooms in a flat type structure buildings, due to its iron network structure reinforced inside its concrete will oppose a considerable obstruction to tv signals to get through. Moreover, if any paerson walk through these telescopic type antenna, picure will get shiver of it will be distrurbed.
So buy an outdoor antenna, and hoist it at suitable place, where there are no obstructions comes between the signal path of the transmitter and the antenna. Get an antenna, whcich has as many as cross elemets, if it is a yagi type. As number of elements increses, the sensitivity and seletivity of the antenna will also increase, resulting in good and detailed picture clarity. OK
Nov 30, 2010 | Sharp 20F640 20" TV
I have tried two different antennas and the screen says that the signal is weak I bought the TV today
If you're using an indoor antenna (rabbit ears), you'll find that there's little difference between them. Yes, you'll see all the fancy knobs, but mostly all they do is delay the signal from making it to your antenna jack, hopefully enough to reduce ghosting on analog channels...or a resistor circuit that reduces the signal strength. Receiving a good signal with an indoor antenna can be difficult...there can be obstacles between your tv and the broadcasting station, you could be too far away...it's hard to tell. Before you use an outdoor antenna (consider a good RV antenna if you need to use it indoors), try an antenna amplifier. It'll have to handle both VHF (at one time channels 2-13) and UHF (channels 14-69 analog). If it's an "antenna amplifier," it will be sufficient. If it's a cable amp, it would be a hit-or miss. The amp may be able to boost your signal with the indoor antenna you have now. Alternately, you can buy an indoor antenna with the amp built in. Hope this helps.
Jan 20, 2010 | Sansui DTV1300 TV
I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the...
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Jul 15, 2009 | Televison & Video
I installed the zenith Digital converter box lastnight..used an digital amplified indoor antenna..only got 5 channels but today its not recieving signal at all and i bought another indoor antenna thinking...
I understand your issue as not getting the Digital reception from your converter box. The antenna plays an important role in what you can get. If you still have the Amplified antenna try to reduce the amplification and readjust the antenna positions. You might have to do this several times until you get it right. Also, if you live in a city and not a rural location do not use an amplified antenna and see if it is any better.
Good Luck.
Jul 12, 2009 | Zenith Analog to Digital Audio Converter
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Digital to Analog converter...no signal
One of the problems with digital reception is if the signal is not strong enough for the converter box/or built in tuner on a new TV- you will not get any picture at all. If you followed all the directions-and the converter box shows no channels- then you do need a better antenna. I don't know how far you are from the broadcast antenna, but a good rule of thumb is if you live 10 miles away, buy an antenna that is good for twice that distance, or further. They are rated in miles of reception
Jun 23, 2008 | Televison & Video
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
HTC Touch P3450 Smartphone Logo
75 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
