Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV powers up green light is solid and no picture
Everything seems to be working except I have no picture. The lamp light doesn't indicate at all. I wonder if lamp could have failed but indicator light not working
  • 2 more comments
  • vesuvius Jan 28, 2008
    No sound and the light is on solid green, no blinking
  • vesuvius Jan 30, 2008
    Thanks, but I tried both and it made no difference
  • Ironsights3 Dec 24, 2008
    I have the same problem with my 52525.
    My set used to have a solid red light even after changing the bulb. I replaced 14 capacitors (including 5 that were severly bulged or leaking). When I restarted the tv: it bliked green (as it is supposed to) then the light went solid green with no picture.
    Any help would be greatly appreciated.
    Tres
  • Cary Farah
    Cary Farah May 11, 2010
    so are you getting sound?
    is the styby led blinking?
    President:
  • 4,402 Answers
>>The first thing to do is a system reset using the recessed button on the front panel.
>>If that does not work, unplug the set and let it sit overnight
SYSTEM RESET button with a pointed item like the end point of a paperclip.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Replaced bulb for a PT-50LC14...worked great til I turned TV on then click off 25 seconds after. 3 hrs later...turned it on and nothing except 8 green blinks on power button then solid red(shuts off) No...
Remove lamp to see if it was not inserted correctly (easy mistake to make) and also make sure door on lamp was closed securely--a safety lever there will prevent set from working if door not engaging the lever.
Jun 17, 2012 | Televison & Video
I replaced the lamp in my Sharp xv-z90u. When I attach the power cord I get a solid green on the power indicator light. I also get a flashing green on the lamp indicator. I tried programming the reset...
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
Feb 21, 2011 | Sharp Projector Lamp for XV-Z90U
Every so often ithe screen just goes blank and you can't change channels or input devices when it does this. There are no blinking lights or no codes being shown, the green power indicator light stays...
It sounds lamp is reaching to end of its working life and causing that problem due to its weak result.
Replace lamp in tv to solve this issue. Lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 01, 2011 | Sony KDF-E502000 50" HDTV
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Sep 17, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
