Question about Dell Axim X3 Pocket PC
How to connect it to a pc running Win XP
Pl. help me.
  • anooof Jan 27, 2008
    Thank you sir,
    I don't have USB cradle at the moment but I have a synv cable.
    Is it possible with a sync cable. And I have already downloaded the software.
    Thanks again.
    Anoof
  • 689 Answers
Simply download the active sync from http://www.microsoft.com/windowsmobile/activesync/default.mspx
And use the USB cradle to connect to computer (You can also use Infrared and Bluetooth). As long as active sync is on the computer system will recognize pocket PC automatically
Good Luck
Posted on Jan 27, 2008
  • ExpressFiX
    ExpressFiX Jan 27, 2008
    Yes you can go ahead and use the sync cable
Need product key for windows xp home edition
PL note down master key for win sp1,2,3
dyy4v-t2mjj-fcwm3-34282-bv3pm
pl do rate if solution is helpful.
Feb 02, 2011 | Microsoft Windows XP Home Edition
Palm m100 hotsync problem
A hard reset will most likely work, but make sure to back up using a third party application.
Nov 10, 2009 | Palm M100
My (Win XP SP2) command prompt does not work
First off, lets try a few things. This will help us narrow it down:
  • Try typing other known commands to see if they work (ipconfig for example)
  • Do a search on your computer for cmd.exe (you should only have 1, and it should be in the system32 folder.)
  • try typing cmd.exe instead of just cmd.
Give those a shot and report back. Depending on which one of these give you a problem, it could point to the correct fix.
The reason I say this is that your easiest solution may be to upgrade to SP3. The only times I've ever heard someone having this problem was also in SP2.
Jul 27, 2009 | Microsoft Windows XP Professional with...
I NEED TO INSTAL WIN XP, BUT ITS NOT SUPPORTING. PL SUGGEST
Your drivers are here, most drivers for this system are loaded by Windows itself.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3860108&lang=en
Let me know if there is anything else you need.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Compaq Presario CQ60-220US PC Laptop
Sending message
pl check the messenger service is enable and running in both server as well as nods (win XP). Hope it will work.
Jun 19, 2008 | Microsoft Windows Server Standard 2003 for...
Canon LBP-1210 driver
Pls Do this
start>settings>Print&Fax>selesc Canon1210
Then, file>server properties
In forms check creat a new form and give name Leagalx
Set Width 8.5in Height 14.00in Left 0.50 Ri 0.50 top 0.50 bott 0.50 then save form and close it.
Open the printer properties select forms > change forms
and select the "leagelx". Ok.
You di it
Apr 19, 2008 | Canon LASER SHOT LBP-3000 Printer
How to work tally 4.5 in windows xp
pls send me reply for this how to work tally 4.5 xp
Mar 14, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Dell Axim X3 Pocket PC Logo
117 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
