Question about Creative Labs Zen Touch MP3 Player
Creative zen touch mp3 player
Turned it on. A screen came up that said this: Recovery Mode____________________ Creative Zen Touch v0.0.8 1. Clean Up ...
    President:
  • 4,402 Answers
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch. if that doesnt work try this:
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again
when you get it working
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Posted on Jan 28, 2008
Mymp3player/zentouch0.8 is showinghardwareproblem/howtorectify
Posted on May 06, 2010
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: recovery disk mp3 creative zen micro
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Posted on Dec 06, 2007
  • 19 Answers
SOURCE: Creative Zen Touch stuck in "recovery mode"
for anyone else who still have unusable devices and the device is not there for the firmware but it is for anything else do this:
1. Plug in the player.
2. Goto device manager remove it's drivers and remove USB Roots (dont worry they'll all reload)
3. Reboot and unplug the player.
4. After windows loads goto add/remove programs and uninstall windows media player. Select downgrade.
5. If it asks you to reboot do so.
6. Then locate c:\program files\creative and just manually delete the folder you can put it back on if you wish later but it's useless and outdated junk.
Now reboot. Plug the device in and install the firmware.
If this works as good for me as anyone else lemme know.
Dan
Posted on Mar 13, 2008
TheGadgetDr
  • 65 Answers
SOURCE: creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Posted on Apr 02, 2008
I have the same exact problem and I haven't the slightest idea what to do. This has never happened before - ever - and I've owned my mp3 player for 2 and half years. It's kind of retarded that Creative doesn't include a troubleshooting section in the manual. HELP!!!!
Posted on Jul 30, 2008
Creative zen touch
Leave it on until it is out of power and recharge it.
Apr 03, 2009 | Creative Labs Zen Touch MP3 Player
My Creative Zen Touch is frozen. When I hold down the "Menu" button, the screen does not change. When I connect to the computer and attempt to run Creative Mediasource Organizer, I get a message that the...
I would run the recovery console from the player itself. Make sure the Touch's power supply is plugged in (and unplugged from a PC) then to access the recovery mode of the Touch, hold down the Play/Pause button while inserting a straightened paper clip into the reset hole on your player, give it about five seconds then remove the paper clip.
Next, keep on holding the Play/Pause button until the Rescue Mode screen appears. After you see the rescue mode menu, you can release the play/pause button.
I would try a "clean up" first, as this is less intrusive and will not erase data.
Mar 27, 2009 | Creative Labs Zen Touch MP3 Player
Hi! I think you should try this (i've already tried it and it works):
1- Unplug your Zen from your Computer.
2-Turn off your Zen (if you can't do it, press the "Reset" button)
3- BEFORE turning on your Zen, press your "Play" button and hold it while you turn on.
4-When a format menu appears, select the "Format All" option (you'll loose all your Zen data).
5-When the format menu reapears, select the "Reboot" option and listo! You have your Zen as new and should not have problem. Good luck!
Jun 30, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Zen Touch in Recovery Mode
can you choose any of the options 1-4? try to clean up.
Jun 24, 2008 | Creative Labs Zen Touch MP3 Player
Have you tried to load the firmware? First you'll need to download the firmware to your PC from Creative's website: Click here. After you've downloaded it, connect your Zen via USB to your PC and open the firmware icon, then click "Upgrade."
For more detailed instructions on how to troubleshoot your Zen, click here
Jun 03, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen mp3 help please
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Creative zen
· Download recovery tool off creative's website.
http://us.creative.com/support/downloads/
Sep 30, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen Touch MP3 Player Logo
492 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
