To recover your data try to start the computer in safe mode.
If this doesn't work try to mount your hard disk on another computer.
Restart the computer and after Bios loads up and press F8.
Then select Safe Mode and press Enter.
Run a virus scan, assuming that you have an Antivirus program installed.
You must have a good antivirus program .
Have you recently installed a new program and/or device?
You should uninstall it from Safe mode if so.
Have you used the System Restore option?
then try it.It may solve your problem.
or else try this Take everything out- RAM, video card, controller card, and all the other adapters. Disconnect the cables from the drives. Turn on the system. A series of beeps from the board should be the result. If there are no beeps: Make sure that the speaker is connected. If the speaker wires are attached, then the motherboard or the CPU are the cause of the problem or it could be a short.
System boots in safe mode, now is running very slow and the caps lock is permanently on. This is a 6...
(More)
System boots in safe mode, now is running very slow and the caps lock is permanently on. This is a 6 month old mac book pro 15" with latest version of OSX
plz do send me the solution on dipankar1985@gmail.com i've formated my laptop SAHARA...
(More)
plz do send me the solution on dipankar1985@gmail.com i've formated my laptop SAHARA brand''AL-096''model and i don't have the system cd..so i want to configure the drivers for it... send me the website link which i can download the driver's from it... thx alot.
