Question about Nikon D200 Digital Camera with 18-200mm Lens
Not functioning d200
My d200 suddenly stopped, during shooting, to take pictures. the body acts normaly, the lens (Nikkor 18-200) seems to be all right,but there is only black on the ltd and on the card?!?
  • Anonymous Mar 21, 2008
    I've reset the camera back to all the defaults, I've taken the lens on & off, I've removed & replaced the battery, I've reset from C to S to M and back to C again,
  • Anonymous Apr 10, 2008
    After 1 year of flawless performance, my D200 body repeatedly stops functioning in cold humid weather, apprx 3° C and below. Sometimes it tells batteries are depleated, although 2 fresh ones ar in the pack. Sometimes it just won't shoot. What's worse, a new photogr just started working at our paper, using D200, and tells the exact same story. I was covering a burning tall building last night and time after time I missed fabulous shots because of this. If there is no working solution I'm gonna have to throw this camera into the sea and get something else. Regards - Sid, Iceland
Nikon D200 High Speed Performance
© 2006 KenRockwell.com Film vs. Digital About these reviews
enlarge
I bought mine from Ritz here. I bought another D200 from Adorama here. Also try Amazon here. Adorama usually has D200/18-70 kits in stock here. It helps me keep adding to this site when you click these links to get yours.
HIGH SPEED PERFORMANCE
General:
My D200 is fast, smooth and quiet. Unlike my D1H, my D200 makes less noise and vibration. It doesn't feel as macho, and allows me to shoot in more places more discreetly. At five frames per second it just hums along sweetly, compared to my bigger cameras which always felt like something was going to come flying off of them from all the clattering.
Buffers versus Memory Card Memory
The D200 uses two very different kinds of memory for storing images.
We're all familiar with the CF cards used to store hundreds of images. These aren't that fast and card makers rate them for write speed. The D200 uses these for recording your images.
The D200, like all professional digital cameras, has a second very high speed internal cache memory called a buffer. You never touch this. This buffer memory stores 25 frames of JPGs, 21 frames of raw or 19 frames of raw + JPG.
The buffer memory is fast enough to store all these frames at the full 5FPS rate, or faster.
The D200 is never slowed by memory speed card. The D200, like other professional cameras, has a second independent set of processors which handle writing the contents of the fast buffer memory to the slower CF card. Because this writing is done with a second set of processors you never know it's working except for the green CF light on the back. The D200 can be busy for over a minute writing to the CF card and you still have the complete ability to shoot at 5 FPS and play back.
The buffer is so deep that even under the heaviest shooting it's unlikely that you'll ever fill it. Even if you fill the buffer you can still make photos and playback, just that the maximum shooting rate will lower a bit until the buffer write and frees up at least one frame.
It takes it a 100 seconds to write 400 MB of data from 19 uncompressed RAW + Large FINE JPG files to my 40x 1GB Lexar card. As a photographer you don't care how long it takes to write. So long as the buffer isn't full the camera works as fast as ever. Even if it is full you can shoot the next shot as soon as the buffer clears enough room. You don't have to wait for everything to write to make a next shot. Even with my slow 40x lexar 1GB card, a constipated buffer and huge compressed raw + JPG Large Fine files I can make a new shot every 3.2 seconds. With uncompressed raw + JPG Fine Large I can get off a new shot with a full buffer every 3.7 seconds. If you ever get to these limits you're doing something stupid. Just shoot JPG and you'll never be able to fill up the buffer faster than you can shoot. With Large FINE Optimal Quality JPGs the buffer clears at the rate of 1 FPS. With Large Basic Optimal Quality JPGs I can run at 2 FPS even with a full buffer. Use the smaller image sizes or the Size Priority JPG setting and you can shoot as fast with the buffer full as empty!
I've had to do seriously stupid tests to fill it up.
Shot Buffer Readout
A shot buffer is fast memory inside the camera which stores the shots you've just made. Your memory card is written from this buffer. Even with the slowest card on earth you can shoot as fast as you want, since it all sits in the buffer until written. Your card is recorded in the background while you shoot. The green CF light tells you this is happening.
The size of this buffer is how many shots it can hold while allowing you to shoot at 5 FPS. If it gets full the camera slows to only as fast as your card will accept data, which is about one frame per second . These buffers are why you don't need to worry about card speed.
I've never filled up more than 9 shots in a buffer. I don't shoot that fast. With a 25 frame buffer the D200 has far more than I'll ever use.
This is the number you see while the shutter button is pressed halfway. It usually looks like [r25], which means it's empty and can hold 25 more shots. Normally you'll see a big number like [527] or [ 1.3]k, which is how many shots are left on your card. As you shoot fast sequences you can see this number drop. When it drops to [r00] your buffer is full and the camera slows down its shooting until the buffer is recorded to the card. It's fun to look at when you get your camera, but since I never fill it up I don't worry about it. You'd have to be shooting many long high speed sequences continuously with a slow card ever to use much of this.
Posted on Sep 07, 2008
  • 3 Answers
Update the firmware - both A & B - There is a bug with the version 1 firmware that in rare cases causes errors with the battery level indicator. When this happens the camera will not operate. In cold conitions the batteries will provide less power and this is probably enough to set off this problem.
Posted on Feb 11, 2009
    Scholar:
  • 33 Answers
What are the settings?  I'm betting you inadvertently either put it on M and the camera isn't letting enough light hit the sensor, or some other simple thing like that is the problem.  Make sure it is set right and let me know if that solves the problem.
Posted on Jan 27, 2008
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Focus On My Subject
Change your metering mode to spot metering. Focus on your subject with half-press of shutter button...hold that press while you re-compose the picture and press the rest of the way. See if you get better results.
Apr 07, 2010 | Nikon D200 Body Only Digital Camera
I have a Telephoto AF Nikkor 85mm f/1.8D Autofocus Lens on Nikon D200 camera body, and I've been using it for a few months with no problems. I love the lens. But a week ago I was in the middle of...
You may want to check what the aperture ring is set at on your 85mm. Nikon SLRs for most purposes, require that the f-stop on the lenses be set at the minimum aperture number, ie f-16,22,32. This is so the camera has the full range of the aperture to control it properly. Most if not all lenses for Nikon have a small button, usually marked with orange, to lock the aperture ring at that setting
Jan 11, 2010 | Cameras
I shoot RAW/basic jpg. I review them there is a contrast differen
This is normal. Bear in mind that the JPEG file has all the image processing done, while the RAW is just the raw data. Depending on your image settings (contrast, saturation, sharpening, etc) you may see some differences.
Nov 24, 2009 | Nikon D200 Digital Camera with Nikkor AF-S...
Using a Nikon D200 with a new 18-200mm lens. When
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI,FIRST READ YOUR LENS SPECIFICATION CAREFULLY IT SAYS 18-200/3.5-5.6 IT SHOULD BE READ AS AT 18 MM IT IS F3.5,THEN AT 200 MM IT WILL BE F5.6 THATS WHY IT MOVES APERTURE FROM 3.5 TO 5.6.IT IS QUITE NORMAL. REPLY ME IF YOU ARE SATISFIED WITH MY EXPLANATION.
Jul 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Error 11 at nikon camera
First, if you can try the lens on another camera body, please do. See if the same thing happens on a different camera body. If it does, it's a problem with the lens. If not, you need to look at the camera. You can verify it's the camera by placing a different lens onto the body and see if you're experiencing the same problem. If it is indeed the body, I would suggest you take a pencil eraser and gently but firmly clean the contacts located on the lens mount. It's my experience (I also shoot with a D200) that often times when a lens isn't autofocusing, it's due to direty contacts either on the lens itself or the camera body. Cleaning them is a good start though and will narrow your issues down to the lens or the camera body. After cleaning, try the lens again to see if it's working correctly. If not, send it to Nikon in New York for repairs.
Jul 11, 2009 | Nikon D200 Digital Camera with 18-200mm...
Lens will not open up all the way
Is the maximum available aperture dependent on the focus distance? Many macro/micro lenses "dim" slightly as you focus in close.
See if you get 2.8 focused at infinity.
May 22, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens
The internal circuit board, or the internal harness may be at fault. You will have to send the lens to Nikon for service.
Jerry G.
Apr 23, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Nikon d200
I would recommend the 17-35mm f2.8D ED-IF rather than the G series
Feb 23, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
REPAIR
OK guys, it seems to be the lenses motor which for some reason burns out. I put a Nikkor 50mm 1.4 mm AF(great lens by the way) on the d200 body and it works fine. I sent the 18-200 in for repair and I won't tell you how much they wanted to charge me to fix it, thank God it's still under warrantee. Suggest you all try out another AF lens on the D200 body to see how that works. If ok then send in your boom lens and pray that your not over the 1 year warrantee limit.
Nov 01, 2007 | Kodak EasyShare C875 Digital Camera
Nikon D200 Digital Camera with 18-200mm Lens Logo
337 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
