Question about Samsung YP-K5JAB MP3 Player
My screen jus froze after updating the firmwire
Hello master .
I have a samsung yp-k5JQB, and got a problem.
When I turn it on. it appears samsung logo, but at the moment of animation on samsung logo apearance, it freez.
I intended 'reset' 153 times, not working.. same.
I tried to connect this to my PC to try to upgrade firmware.
When I connected it, PC shows a 'beep' sounds that means an USB equipment connected, but I cannot find any MTP device, or any additional disk.
How can I fix this problem?
Do you know it?
Have exactly the same problem as KAOSaurusREX. haven't tried 150 times though!
Re: my screen jus froze after updating the firmwire
If you updated firmware and this problem showed up , then you will have to send it back to samsung for the firmware upgrade. Your upgrading may have had a corruption in the firmware you uploaded.
Posted on Mar 02, 2008
0 characters
3 Points
Nead charger of MP3 Samsung mod. yp-k5jqb (si es posible me contesta en espanol) gracias
Check an electronics store like Best Buy or hhgreg. I would even check Wal-Mart to see if they have one in stock. I'm not familiar with MP3 players, but this is the best advice I can give you.
Sep 29, 2010 | Samsung YP-K5JQB MP3 Player
Lost installation cd for samsung YP-K5J QB and i want to find it for free
All links for manuals, software and firmware can be reached on next site:
I'd appreciate your vote if this was helpful. When needing more help just add a comment.
Apr 06, 2010 | Samsung YP-K5 MP3 Player
Colour change?
google yp-k3 firmwire , ul come across a file to change the colour of your player , mind you u can only have 1 at a time and each time u wont to change u have to re flash it :(
Aug 25, 2008 | Samsung YP-K3 MP3 Player
My samsung YP-K3 MP3 Player problem
on the bk is a small reset button try that 1st :)
faling that maybe a firmwire issue , try updating it or rolling it bk
Aug 22, 2008 | Samsung YP-K3 MP3 Player
Yp-k3 samsung Mp3 Screen Froze On "Remove Cable"
My daughter had a similar problem - she was frozen at the power off screen. On closer inspection, at the bottom of the K3 on the back of the unit is a reset button (you will need a pin or paper clip to reset it). Pushed a pin in for a few seconds, reset, all was OK.
Aug 21, 2008 | Samsung YP-K3 MP3 Player
Can install new firmwire
1. Download Winrar here, its a freeware, this will help you open the file
2. Download the firmware here, the newest one is 4.13
3. Unzip the firmware file and select "extract to" using winrar, just extract it to the "desktop"
4. After the 2 files are extracted from the folder, select both of them, right-click and select "cut"
5. Now, go to "My Computer", double-click "P2" (that's the MP4 player) and double-click "internal storage", now, in this directory, "Paste" the 2 files you "cut" earlier, once the files have been successfully pasted (look at your PC screen and MP4 player and make sure nothing is transferring), exit the window, unplug the MP4 player and power it on, the player will be updating and turning of a few times, but once its of, turn it back on until the whole process is finished.
May 22, 2008 | Samsung Yepp YP-P2 Digital Media Player
MP3 player has froze at startup screen
Reset, upgrade firmware:
Mar 25, 2008 | Samsung YP-K3 MP3 Player
Firmwire upgrade, Spoiled my mp3
my yp-u1 mp3 have cracked the cover, so do you have the cover of yp-u1 to repair?
May 22, 2006 | Samsung Yepp YP-U1X MP3 Player
Samsung YP-K5JAB MP3 Player Logo
110 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
