Question about IBM ThinkPad T30 2366 Notebook
T30 won't turn on
I have an IBM ThinkPad T30. I push the power button and all five icons light up. After about a second, four turn off leaving only the "Z" icon lit green.
On the monitor the battery icon is green and the moon icon is not lit.
No water has gotten anywhere near this computer. I was using it this after noon, turned it off, and now (~3hrs later) it will not turn on.
  • 2 more comments
  • ericstrash Jan 27, 2008
    I had tried the statical lockup solution, I just didn't know the terminology. What I ended up doing was removing the battery, removing the CMOS battery, removed the memory, removed the HDD, removed the DVDROM, then removed the keyboard/power button and used OFA to blow out any debris. While I was in there, I removed the top panel completely and blew all the dust out. Then I reassembled the entire PC, reseated all the peripherals, and booted up without the battery installed. I reset the BIOS settings, and successfully booted windows. Tehn I powered it down through the start menu and reinstalled the battery. All seems to be OK now. Thanks for the assistance!
    Eric
  • KennethMull Feb 10, 2008
    Same problem as Ericstrash but problem still exist after changing motherboard.
    No water has gotten anywhere near this. The problem came about once I attempted to fix one of the RAM slots by re-soldering. Since then I have replaced the motherboard and it's still doing the same thing as ericstrash Jan 2008 mentioned his is doing. I tried all the advice that was posted as of Feb 08 2008 with no luck. Is there any additional advice available? What the chances of the inverter (LCD) being bad? Please help
  • mcltech Oct 06, 2008
    I was trying to boot to a USB floppy drive. The Boot Selection screen came up (1 Fxx key to boot normally, another to go to BIOS setup, another to boot to an alternate device). The PC hung. I pushed the power button to force shutdown (10 second push). Since then, on power-up all 5 LEDs come on, then just the power-on LED, and nothing else happens. Powers down OK with power switch.
    I have removed RAM, Hard Drive, Keyboard, backup battery, main battery, and no improvement. Held power button down for 1 minute (static discharge clear resolution, if I remember correctly), still no improvement. Replaced backup battery, then RAM, still no fix.
    HELP!!!
  • javis_izcall Dec 02, 2008
    Same here. One day I was using my T30 2366 without problems. Next day press power button and nothing: No boot, no video, nothing happens. Power light is on, Fan is working, HDD too (it sounds) but the screen is black, I tried to switch RAM with my presario C304 but it wont fit (why?  its the same kind) Same thing with external monitor attached. I opened the thing up to sense CPU´s temp. with laptop ON: It gets hot as it should be. I dont want to send it to service (it would be cheaper to buy another one)  It would be nice to hear Any more ideas....
  • 689 Answers
It might have some statical lockup
Here is the steps that you may try
Disconnect the AC adaptor, take the battery out, press the power button and hold about 7 second. Connect the AC adaptor and turn the unit on. If issue persists please post for further diagnostic.
Good Luck
Posted on Jan 27, 2008
    Novelist:
  • 171 Answers
This is a difficult problem to diagnose, there are many reasons it could happen. I can give you some suggestions about what you can try:
1) Check your power supply, try to run on batteries instead, or if you are running on batteries, take the battery out and try running only on AC
2) Reseat the memory, i.e. take it out, put it back in, make sure it's snugly in
3) Reseat the hard drive, just like you did with the memory
4) Check if the power button is making intermittent contact. Remove the top panel and inspect the power button's contacts for dirt/debris.
You will need to refer to your thinkpad's manual for instructions on how to do the above operations. There are specific disassembly instructions. You can find a copy here:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62733
I tried most of what has been written above. My problems seems to be with the Memory slots. If I re-seed the memory it seems to works. I've now wedged some folded paper between the cover and the memory. No problems yet.
Posted on Jul 30, 2008
This message is just a huge thank you to Frosty555... It had been three days now that my T30 wouldn't boot, or maybe once in fifty tries, just to freeze few secondes after....
There was actually a dirt under the RAM which prevented the T30 to work... I was almost resigned to buy another one, but thanks to you, I saved some good money !
Alek
Posted on Feb 09, 2008
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad won't turn on
Try powering on laptop what happens do you hear any beeps or see any lights normally if u see lights this is a sign that it is working if not your motherboard could be bad if you see lights and hear constant short beeps this means your memory can be bad, Try powering on laptop without battery and only power supply plugged in.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad t30 will not start
You should charge the battery longer about four hours. Then the light should be green. Try. If that don't work disconnect the battery and check for anything. Connect your battery again and take a look. If it still isn't functioning please let me know.
Dec 25, 2008 | IBM ThinkPad T30 2366 Notebook
How to get rid of numberlock in ibm thinkpad t30
Hi Ritadeng,
On the Thinkpad T30, the number lock key can be turned on or off by pressing the shift-key and the scroll-lock key. The scroll lock button is found at the top of the keyboard between the PrtSc button and the Pause button.
You should see the light with the arrow and the number 1 inside (just above the F7 key) turn on and off when you press this.
Hope this helps!
David
Nov 18, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
IBM THINKPAD T30 BOOTUP PROBLEM
Hello I ahve worked on several of these. The problem is the Jack on the motherboard. You need to get a motherboard that is brand new. The jack from pluging in and out all the time makes a hairline crack near the jack.
Feb 10, 2008 | IBM ThinkPad T30 2366 Notebook
No power on my thinkpad 2366-41u
I have seem power jacks break sometimes - was the machine working until the battery died??
if it knows its plugged it (charge light comes on) but does not turn on, it could be a bad keyboard (the power button is part of the keyboard) or some other internal problem. Hard to say without having spare parts around or a qualified hardware tech to check out the machine.
You could always order a keyboard and try it -they are cheap online and easy to install (i think 3 screws on the bottom of the machine with a keyboard icon next to the screw holes)
Hope this helps!
Dec 20, 2007 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 no power
I agree with you and have a link for adapters http://www.google.com/products?q=IBM+ThinkPad+T30+2366+adapter&hl=en&rls=com.microsoft:en-us&um=1&sa=X&oi=froogle&ct=title
Aug 02, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
3,703 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
