Question about Panasonic CT-32SL14 32" TV
No response from remote
Just noticed that my television is not responding to the universal remote although the remote has a set of fresh batteries. This remote worked well with the tv before. I tried the original remote for the tv which is new and no response is received. Kindly advise. I've an older Panasonic television and a small GE universal remote that has been working...it stopped, though; so, I replaced the batteries and it still doesn't work. I cannot find the manual...can you help me? Thanks
  • 281 Answers
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Posted on Jan 28, 2008
Just replaced the power supply Backlight inverter to Vizio Model E470VL TV. It works fine now but I can't get the remote control or a Universal remote to work. Do I need to purchase a special remote?
If the remotes have good batteries and are both working, and the set still does not respond, you might try to reset the sets electronics. If that does not do the trick then the board responsible for responding to the remote signals generated has an issue.
Feb 23, 2017 | Vizio Televison & Video
Although the remote has been connected to the television, the television does not respond to some of the buttons, what do I do?
Your universal remote control may not have a code capable of enabling all functions of your TV. Not all universal remotes contain the same code set so you may have to try another one.
Sep 15, 2014 | Televison & Video
Sony tv not responding to remote control.Was working fine an houir ago?
I guess the first thing I'd have to say would be to replace the batteries on the remote and see if that helps at all.
If it's the remote that comes with a cable box, try the remote that came with the TV when you bought it.
I would narrow it down to being either the TV that's the problem, or the remote. Borrow a friend's remote, and program it to work with your Television.
Perhaps a site such as the following will help http://www.ehow.com/how_8446_program-sony-universal.html
What is the exact model of your TV?
Mar 05, 2011 | Televison & Video
Need code for a phillips universal remote for zenith tv/vcr model tvsc2040f
you can get the code automatically by pressing set button the remote then after keep pressing the volume key while you observe the tv for response once you notice any response press the set button again.now its ok.
Sep 24, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
TV LC32SB24U will not respond to the remote control. I check the remote signal using a camara cell phone by pointing the eye of the remote towards the lens of the cell phone camera. I press each button on...
Are you using a remote from a cable issued cablebox or the orginal remote? I noticed my cable company DVR remote stopped working when the OPC setting on the Picture menu of the TV was set to the 'ON' position. Once turned to the 'OFF' position it stopped the OPC feature from activating which seemed to interfere with the response of the remote for some reason.
Mar 22, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV not responding to remotes
I ASSUME IT'S JUST THE REMOTE YOU'RE SPEAKING OF- FIRST, IF YOU HAVE A DIGITAL CAMERA, OR CAMERA PHONE, AIM IT AT THE INFRA-RED LED'S ON THE FRONT OF THE REMOTE, AND PRESS BUTTONS [LIKE POWER OR CHANNEL] - THE CCD'S USED IN DIGITAL CAMERAS ARE VERY SENSITIVE TO IR, AND YOU SHOULD SEE A WHITE LIGHT [IMAGE] OF THE LED'S, EITHER STEADY, MOMENTARALLY, OR PULSING. IF THE REMOTE HAS BEEN DROPPED, THERE IS A CCHANCE THE CRYSTAL CONTROLLING THE FREQUENCY HAS BEEN DAMAGED. TRY A UNIVERSAL REMOTE, ALTHOUGH OFTEN YOU MAY LOOSE SOME FUNCTIONS, OR THE BUTTONS REACT DIFFERENTLY THAN LABELED. SELDOMLY, BUT IT DOES HAPPEN, THE IR RECEIVER SECTION OF THE SET ITSELF CAN FAIL. THE IR RECEIVER [LOOKS LIKE A DARK LED] CAN FAIL, AND THEY'RE COMMERCIALLY AVAILABLE AT RADIO SHACK
Feb 28, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
JVC I'art flatscreen TV remote doesn't work
This maybe a sticky one.
#1. Original remote may have something spilled in it or may have dirty battery contacts.
First check battery contacts and make sure it's not corroded. Clean with small brush and baking soda. Let dry thouroughly and replace with fresh batteries.
If this isn't the problem or you tried this, then move on.
Next, Get these materials. A cloth, 50% amonia and 50% water sulution two small blad pocket knife and a philips head screwdriver.
Some remotes will have screws holding remote covers and internal board and others do not. If your remote have screws, remove them all. If not, then start prying your remote apart with your pocket knives. Do so very carefully as not to damage anything inside.
Next, lay down remote button facing down, and remove circuit board. Now, take note of rubber button pad(s) position(s) and remove them. Place these pads in your water - amonia solution.
Clean all cntacts and rubber pads, and remote housing. Now before reassembling remote, look at the IR lamp at end of board. Look underside and notice solder joints. Wriggle lamp and see if solder joints move. If so, have this resoldered. Now reassemble remote and give this a try.
#2) Codes may have not been entered right with your new universal remote. Go through all codes again just to be sure.
#3) IR receiver in set maybe damaged or not receiving power to it or the microproccessor has quit responding to the remote commands. Have a good technician check into it if problem is evident that your set has simply stopped responding to remotes.
Good luck,
Jason.
Jan 07, 2009 | JVC AV-27530 27" TV
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Panasonic CT-32SL14 32" TV Logo
198 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
