Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not turn on
When i hit the power button it stays on for a split second. both the dvd and vcr lite is on. i cannot eject my tape or remove my dvd
  • fluffy333 Jan 27, 2008
    how do i get the tape out
    i got the tape out--how do i get the dvd door to open so i can remove the dvd
    Problem Solver:
  • 5 Answers
It sounds like the VCR ate the tape. When this happened to me (with a different brand name) I took the top off of the unit and carefully removed the cassette and DVD.
USE CAUTION WHILE DOING THIS AND DUH!!! UNPLUG THE UNIT BEFORE REMOVING THE SCREWS!!!!!!
You should unhook the unit from the tv connections and take it to the table or other flat surface. While it is unplugged!!! remove the screws and remove the top of the unit. BE CAREFUL not to remove anything else!
Simply remove the cassette and DVD. Then plug in the power and make sure it comes on properly. Open the DVD tray to make sure it works also.
Then reconnect the unit to your tv and ENJOY!!
Trust me, it works... I've done it several times. I cannot promise that your problem is an eaten tape... but it sounds like it and when this happens 90% of the time, it triggers the unit to "turn off" due to a problem. Therefore, you turn it on and the unit turns itsself right back off!
I believe this will work for you :)
Posted on Jan 27, 2008
  • sprinkle Jan 28, 2008
    When you remove the top of the unit, there should be a little "holding bar" across the top of the section where the DVD is. Remove that little bar and pick up the DVD. The same way you removed the VHS. FOLLOW THE SAME CAUTIONS AS BEFORE!!
    Had it eaten the VHS??
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Vcr seems to have quit, will not eject etc
If you can see that your VCR has power (lights up) when you turn it on, but it still won't eject tape, then unplug for a and hour or two. When you turn it on again, it should reset itself and start up. Then you should be able to eject cassette.
If there is no power at all, or you think the taped is jammed and you want to save the tape, remove the top panel of the unplugged VCR and gently remove the tape. Good luck!
Feb 05, 2014 | Pioneer DVR-RT500 DVD Recorder/VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Nov 03, 2009 | GoVideo DVR4000 DVD Player/VCR
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Vcr tape stuck in unit
Marvin,
I am not registered here as an expert, so there should not be any charges. I do not have the option of chatting I am guessing only the registered experts have that. Here goes: 1. Take a phillips screw driver and remove all the screws that are holding the case on, there will be some big ones on the sides and a few maybe smaller ones on the back. 2. Lift the the case off 3. You should see the tape on the inside the vcr 4. You may or may not have to remove some of the metalic shielding which should be only anywhere from 4-6 screws if you have a piece of metal directly over the vcr tape some have them some do not. 5 Gently pull the magnetic tape up from around the feeder posts and the drum. 6. Try and work the vcr tape up and out, If you are having extreme difficulties with this try plugging the vcr back up and pushing the eject button while still holding the magnetic tape. The tape should eject now and you and carefully pull it out. 7. When you get the tape out, use your thumb to push up and turn one side of the white reals on the tape to slowly wind the magnetic tape back inside the tape. 8. Unplug the vcr again and replace everything that you had to remove and replace the cover.
I hope this helps and let me know if you need further assistance. And since I am not a registered expert here there should be no charge for this help unless you chatted or got help from one of the registered experts.
Jul 05, 2008 | Samsung DVD-V5500 DVD Player/VCR
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
