Question about Gigabyte GA-6VXE7+ Motherboard
Problem when i'm booting up ,it tell me that it an unknown flash type n GRUB loading stage 1.5 GRUB loading, please wait..... error 17
Thanks i gonna try this one ...
Posted on Mar 12, 2008
    Genius:
  • 1,067 Answers
Try to re update that bios ok flooppies or flash
Posted on Jan 27, 2008
  • nick helpap
    nick helpap Jan 27, 2008
    cd maby too put new bios on then boot in
Grub loading stage 1.5.,Grub loading please wait,Then it say Error-18
Because Grub has to fit in a small space on the disk, there is no room for helpful error messages, but 'Error 18' translates as 'Selected cylinder exceeds maximum supported by BIOS'. In other words, your BIOS - which initializes hardware - is unable to handle a hard drive this large. Windows is able to boot because the Windows partition is at the start of the distro's disk, within the area handled by the BIOS. This is not a limitation of Linux, which hasn't even started to load, but your hardware. You would see the same problem if you tried to install two versions of Windows, say 98 and XP. There are a few ways to deal with this.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Mar 05, 2012 | Compaq Armada M700 Notebook
When start my laptop, get an error msg. "Grab loading 1.5, please wait.. grab loading error 17. and i can not boot from cd / dvd too..in HP nx9010. Plz help me.
This grub loading error 17 means that the file system type could not be recognised you should be able to boot from a cd make sure the cd or dvd drive is enabled as the first boot device in bios
I hope this helps
Andrew A
Apr 01, 2011 | HP Compaq Business Notebook NX9010
ASUS Eee PC 900 Notebook when I turn on said grub loading stage1.5 then said grub loading . please wait ...and Error 17 ,how do i fix it ???? plsss any1 help meeeeee plsss,
sorry folks but youve corrupted your bootloader (grub) unless you can restore to factory settings(you might be able to my asus its F10(whilst booting) if you have corrupted your system beyond external repair your only option is to use an external drive and use your operating system restoration discs to restore drivers and O.S
Mar 14, 2011 | ASUS Eee PC 900 PC Notebook
When I turn on my laptop I get a GRUB loading , please wait ... Error 22 What can I do ?
GRUB is the boot loader, it's corrupted. It can't be fixed without special disks so in your case the easiest way is to reinstall.
Oct 22, 2010 | Computers & Internet
Computer wont boot, recovery disk doesn't work after reinstalling it says an error has occurred.
There are two ways, choose which is suitable for you: 1) If you deleted a Linux partition and want to get rid of GRUB: - Insert your Windows CD. - In your BIOS settings, select boot from CD/DVD. - After the welcoming screen, type R (to enter the Recovery mode). - At the console (command-prompt/terminal) type: fixmbr - Everything should run fine after that. 2) If you installed Linux and have a problem with GRUB: - Insert your Linux distro CD. - In your BIOS settings, select boot from CD/DVD. - Enter the Live desktop and open a terminal. - Type: sudo grub -Type: find /boot/grub/stage1 (You might receive more than one location. Select the one you want to install GRUB onto) - Type: root (hd?,?) (Where "?" is the location you want to install GRUB) - Type: setup (hd0) (This is to install GRUB onto mbr) - Type: quit (To exit grub) - Reboot and everything should be fine.
Aug 20, 2010 | Computers & Internet
On switching on a black screen appears saying GRUB loading stage1.5. RUB loading, please wait.... Error 17
Please let me know the make and model of your printer, so that I can help you with your issue. And GRUB? You are using Linux? Fedora?
Dec 27, 2009 | Office Equipment & Supplies
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
Reformatted hard drive won't boot
The grub loader is for linux, what it is telling you is that the file the boot loader is looking for was not found (that would be the case because you just reformated it). grub will also complain and fail to boot if the boot file is located past track 1024 (wich would be the case if you installed a significantly larger hard disk). I think what you need to do is delete all the partitions using windows (or dos)
re partition the drive (that will usualy reload the standard boot loader) and see what happens. if you need to install linux then install it on the first partition.
Jan 22, 2008 | Toshiba Satellite A15-S157 Notebook
Dale
u can try to reinstall grub loader, with a linux cd .... (there is the danger of losing all u're data) To avoid that u can try booting with a linux "Live CD" version, to try and save u're work , and also try to diagnostic the drive ....
Jan 19, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Gigabyte GA-6VXE7+ Motherboard Logo
124 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
