Aftron Washing Machine draining power
I just wanna ask why my Aftron washing machine can't drain the water, after the washing period. I already lowered the hose, and tried plugging it to different power outlets. I bought it in Dubai but when I shipped it in the Philippines, the washing is fine, but the draining failed.
The model is SW5L4/M
230-240V, 50Hz, 0,05-1 MPa
5kg, 13A, 2200W
Made in EU
    New Friend:
At the front bottom remove the cover. ..you can see at your right side plastic tap..unscrew it...water and obstructions will flow out...
You will be happy after that. .
I did and now I am happy
Posted on Sep 04, 2016
  • 45 Answers
Check and see that the entire drain line is free from any obstructions, if you have lowered the hose and still not draining entirely, its a sure sign of obstruction somewhere in the drain line or even the drain pump.
Posted on Jan 27, 2008
6ya staff
SOURCE:
Water not draining from washing machine
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Mar 08, 2013 | Washing Machines
My LG Steamwasher is not draining
Jan 18, 2013 | Washing Machines
How to change drain pump and how much does it cost
Check in this link for cost of the drain pump.
Sep 03, 2012 | LG WM2301HW Front Load Washer
Washing machinr won't drain the soapy water.
It is a common fault that the drain fails to work inmost machines in a period of time and is the most problematic fault in awashing machine. In all occasions it is important that your observation is mostimportant and so is vital to the identification /rectification and solution. Ifyou have noticed that water has leaked then as the drain hose pump/valve andfittings are located on the underside of the machine it is important that youlook for possible leaks here. In some cases the drain hose would be clogged atthe drain end to outlet of the house and so there will be back flushingresulting in overflow to the outside. Also the drain pump/valve can be clogged.Now remove the drain hose clamps and remove the drain pump/valve, clean thedrain pump/valve, use back flushing to clear off all dirt. Now test using powerto see if this works and can be simulated. When refitting, the hose must be tightenedproperly. If the pump/valve does not work even with power then it must bereplaced. If there is intermittent powerto the drain valve/pump then the program controller unit is a suspect.Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use aspirit level- so that all water will drain to the outlet port and thereby thereis no residual water remaining. Replacing the pump on a Bosch machine, please checkthis link for tips:http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 29, 2012 | Estate Washing Machines
My LG washing washing machine Fuzzy Logic 6.5kg WF-T6560NT won't drain
Jun 12, 2012 | LG Washing Machines
Washing machine not draining water
Thank You for using fixya
Sep 22, 2011 | Hotpoint Washing Machines
Hi my wirlpool awm 5100 washing machine front loader is not draining when it goes to the draining part it makes the drain noise but there is only very little water getting drained. I think the drain filter...
Aug 02, 2011 | Washing Machines
Odor coming from washing machine - smells like sewer gas
The odor coming from your washing could indicate a problem with your
hot water heater or possibly your city's cold water supply line.
In some cases the odor might be originating from the drain located adjacent to
the washing machine. During long periods of inactivity, if no water is flushed
down the drain, a sewer smell will be emitted from the drain. To alleviate
this condition, just flush water down the drain.
I hope this helps you solve your problem.
Jan 17, 2011 | GE Washing Machines
With my aftron automatic top loading washing machine, I am facing following problem :- 1. It does not have any problem while washing cloth or while water drain, but after it washes cloth, it cannot able...
We have AFTRON FULLY AUTOMATIC TOP LOADING WASHING MACHINE BOUGHT IN 2002 FROM DOHA QATAR. WE COULD HARDLY, USE IT FOR A COUPLE OF TIMES IN INDIA. ALL OF A SUDDEN THERE WAS SMOKE COMING OUT OF THE MACHINE AND FINALLY, WE FOUND THAT THE CIRCUIT HAS GOT BURNT ON THE PCB. NO BODY KNOWS THE SOLUTION IN INDIA.
I WENT TO AFTRON'S H.Q. IN UAE BUT INVANE.
PLS. ADVISE US.
RGDS.,
Aug 14, 2010 | Washing Machines
Washing still wet after washing machine cycle. After full cycle the wahing in the machine was still soaking wet
Either the pump is not emptying the machine quickly enough, or the drum is not spinning. This could also be because there is too much water left in the machine. Check that the drain hose is not blocked and that water is draining/pumping out of the machine. A partial blockage will extend the drain period and the machine may not have time to empty the drum...Good luck......Nomess
Apr 18, 2010 | Washing Machines
Washing Machines Logo
638 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
