Question about Hitachi 50DX01B 50" Rear Projection Television
No Power The television just lost power and will not turn back on. Other items work in the outlets so the power outlet is fine. Any ideas?
  • Hitachi Master
  • 5,138 Answers
Yes take it to a repair shop . unless you know how to repair it.tv has power supply problems shorted hori out put transistor.open pico fuse 5amp etc...ect,,,ect.....Its hard to say what might be wrong with your tv untill trouble shooted by techician.
Posted on Jan 27, 2008
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
42 inch plasma screen tv Panasonic was working fine then turned it off and now won't turn back on. Any ideas? Can't tell if it's getting powered and none of the caps are bulged
Did you try the outlet that your TV is plug into. or get a extention cordand try your TV in other outlet.Then you know if it's the TV or the outlet.
Jan 14, 2013 | Televison & Video
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lost electrical power at 2 outlets. No TV power
wires could be crossed or burnt out
Jun 14, 2009 | Televison & Video
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Gateway flat panel TV will not turn on, the front on and off switch doesnt work at all and when you use the switch in the back the front on and off switch lights up but tv still will not turn on. Is
This sounds like you have lost your power supply. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. If this does not work, please try our premium service or use our online listing of technician for a professional near you.
thanks and good luck :)
Jun 20, 2008 | Televison & Video
TV won't come back on
You have the right idea. The problem is power. If you have had a recent electrical storm or your power grid is "dirty" (spikes and brownouts in electricity) then your television's power supply/converter could have been damaged. Or there is a short in the television. I recommend trying a couple of things before calling a local technician. First, try plugging the television into a different outlet. If the outlet was shorted out then the television could be protecting itself by shutting back down. There could also be a problem in the polarity. Most hardwar/electrical stores sell outlet testers that you just plug into the wall. The device will tell you if the outlet it working properly. If that does not work, then contact your technician. If they can repair the television then you will want to make sure you plug your television into a surge protector (not just a powerstip). Good luck. :)
Jun 19, 2008 | iLO 2600 Television
Ilo-2600hd tv
You have the right idea. The problem is power. If you have had a recent electrical storm or your power grid is "dirty" (spikes and brownouts in electricity) then your television's power supply/converter could have been damaged. Or there is a short in the television. I recommend trying a couple of things before calling a local technician. First, try plugging the television into a different outlet. If the outlet was shorted out then the television could be protecting itself by shutting back down. There could also be a problem in the polarity. Most hardwar/electrical stores sell outlet testers that you just plug into the wall. The device will tell you if the outlet it working properly. If that does not work, then contact your technician to see if they will do the warranty work. You may have to call the manufacturer. They may require that you ship your tv in for service. Make sure you ask for a replacement. They should pay for any postage. If they can repair the television then you will want to make sure you plug your television into a surge protector (not just a powerstip). Good luck. :)
May 31, 2008 | iLO 2600 Television
Hitachi 50DX01B 50" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
