My printer I have a lexmark all-in-one printer x4270 and the power will not turn off and will not print fax scan or make copys. please help
    Sergeant:
  • 390 Answers
Nasty little poop. (the printer not you!) It sounds like the temporamental cheeky thing has a bit of a hiccup. Turn it off, unplug it, replug, turn on, and try and print now. If no good, is it a stand alone unit, because you can then try uninstalling it, and reinstalling it using the cd driver disc. Post back if no good cheers lilacgerry xxx
Posted on Feb 10, 2008
There are black vertical lines going down the middle of the page whne i copy or scan and fax documents. What is the problem.
It could be due to some dirt on the scan lens on the printer. Refer to this article on How to Clean the Scan Lens and White Roller on the Lexmark X4250/ X4270/ F4270. I hope this helps.
If you need additional assistance. please contact Lexmark technical support so they can help you. thanks.
Nov 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 4270
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X4270) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Help with fax please
Please click the below mentioned link to download the Fax Solutions software. But, it is supported for upto XP.
Fax Solutions Download
Thank you
Dec 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Jul 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 all in one
try cleaning the scanner glass it might have dirt settled on it.Had a similiar problem solved by cleaning it.
Jul 02, 2008 | Lexmark X4270 All-in-One Multifunction...
Lexmark X4270 won't install
if possible try a different wire or usb port
check if there is a usb conflict
just some thoughts,
good luck
Nov 12, 2007 | Lexmark X4270 All-In-One InkJet Printer
48 people viewed this question
k24674
jasbo
jasbo
