Question about Texas Instruments TI-83 Plus Calculator
No x and y axis!
When i graph, the x and y axis arent there!
  • Anonymous Oct 10, 2008
    Il n'y a plus l'axe des X et Y
Hit [2nd] [ZOOM] and make sure "AxesOn" is selected
Posted on Jan 28, 2008
Draw a line graph of water temperature vs time
On the x-axis (horizontal axis) represent the time variable. On the y-axis (vertical axis) represent the temperature.
Mar 03, 2014 | Texas Instruments TI-84 Plus Calculator
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
Jun 15, 2011 | Texas Instruments TI-84 Plus Calculator
Find the equation of the hyperbola which satisfies the given equation center(1,-2) transverse axis to the x-axis transverse 6 and conjugate axis 12
I am not quite sure how the major axis of your hyperbola is directed and i do not know if the lengths you give are measures of the major and minor axes or the measures of the semi-major and semi-minor axes. So I am giving you the equations and the graphs so that you can decide for yourself what is appropriate for your problem.
Major axis parallel to the X-axis
Equation and graph
Center is at x=1 and y=-2, semi-major axis length is a=6, and semi-minor axis length is b=12
Major axis is parallel to the y-axis
Equation
Center is at x=1 and y=-2, semi-major axis length is a=12, and semi-minor axis length is b=6.
I trust you can customize the equations to fit your need.
Mar 24, 2011 | Office Equipment & Supplies
I have this different type of graph, it is onle showing the right side of my graph...I can only see the positive x axis. How do I change it to the full graph, where I can see the positive and negative x...
Press MODE to bring up the mode screen. Use the arrow keys to highlight "FULL" on the eighth line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Feb 03, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-nspire doesn't seem to be able to find intersections. When i'm trying to find the intersection of the y axis and a line, it asks me for 1st and 2nd graph instead of lower and upper bound, as I...
The intersection function on the t-nspire is meant to find the intersection of two graphs, not of the graph and an axis. The easiest way to do this is to set the equation equal to 0 and then use nSolve() to find the intercept.
Sep 22, 2010 | Texas Instruments TI-Nspire Graphic...
Why is it true that at x-intercept, the value of y is0, and at y-intercept the value of x is 0?
The x intercept is where the value of y when graphed lands directly on the x axis. The value of y anywhere on the x axis is zero. The same is true for the y intercept producing an x value of zero. The point at which the graphed line intersects the y axis gives an x value of zero. The value of x anywhere on the y axis is zero.
Jan 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Admission to a professional course is subject to the following condition: a) Marks in mathematics > = 60 b) Marks in Physics > = 50 c) Marks in Chemistry > = 40 d) Total in all three subjects >...
So:
X >= 60
Y >= 50
Z >= 40
Take 51 sheets of "graph-paper" (1+200 minus 60 minus 50 minus 40).
On the first sheet of paper, label the graph-title as 'Z=40'.
Label the X-axis from 60 to 200.
Label the Y-axis from 50 to 200.
Draw a straight line from (X=60 and Y=(200-60-40))
to (Y=50 and X=(200-50-40)).
On the second sheet of paper, label the graph-title as 'Z=41'.
Draw a straight line from (X=60 and Y=(200-60-41))
to (Y=50 and X=(200-50-41)).
On the next sheet of paper, label the graph-title as 'Z=42'.
Draw a straight line from (X=60 and Y=(200-60-42))
to (Y=50 and X=(200-50-42)).
On the second sheet of paper, label the graph-title as 'Z=43'.
Draw a straight line from (X=60 and Y=(200-60-43))
to (Y=50 and X=(200-50-43).
Keep going for all 51 sheets of graph-paper.
Stack the 51 sheets on top of each other,
to visualize the "3-D" solution to the problem.
P.S. Don't tell your school-teacher that I helped you do your "homework".
Nov 04, 2009 | Microsoft Computers & Internet
My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
TI-82 graphing problem
You must press 2nd then "zoom", then go down to axes, and turn them on. Now your graph will work again.
Jan 29, 2007 | Texas Instruments TI-82 Calculator
Texas Instruments TI-83 Plus Calculator Logo
116 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
