posted by atchambers on Jan 27, 2008
I have a Centrex Split System Air con and now when i turn it on it just uses the fan it wont move into the run mode and start cooling. Any suggestions
Comment by atchambers, posted on Jan 28, 2008
Thanks heaps for your info, it is all working again now!!!!!!!
1 Other User Has The Same Problem
Comment by steve4814, posted on Mar 21, 2008
I have a GE Portable a/c, the fan works, but does not Cool. I get an "E4" on the display. Any suggestions ?? Thanks Much
Best Solution
posted on Jan 27, 2008
Could be the thermostat or the low voltage line to the outside. Usually a dog chews through it or the weedeater hits it and breaks connection. Turn on cool, go outside and see if it gets 24 volts to the two wires going to contactor (have to take off cover to get to it) DO NOT TOUCH THE CONTACTOR IT HAS 240 V AT ALL TIMES, unless disconnect is thrown, so turn it off. If you aren't getting anything, then it's either the low voltage wire broken somewhere or the thermostat malfunctioning. Make sure you turn off the inside unit before messing with thermostat or you will pop the transformer. If it pulls the contactor in, and you still aren't getting anything, then check for voltage on the load side of contactor (opposite from the inlet or lead side). If you are and you hear a hum from the compressor and the condensing fan motor is running, then it's your compressor. You'll have to remove the top cover to do the next step. Check to see if it when to ground by using a meter set on resistance and with the connector to the compressor removed, put one lead on one of the copper pipes going up to it and touch the other lead against any or all of the pinouts on the compressor. If you get a reading, it went to ground and you will need a new compressor or whole new condensing unit, depending on the age of the one you have now.
Rating Locked! (?) atchambers has rated this solution as FixYa!
This Problem Also Relates To:
GE (AJCQ08ACB) Air Conditioner
GE Profile ASM10AA Air Conditioner
Kenwood KW85 Air Conditioner
Panasonic CW-XC104HU Air Conditioner
Continental CE-PAC1062 Air Conditioner
Continental Electric CE-AC75271 12,000 Ductless Mini Split System with Digital Remote Air Conditioner
DeLonghi Pinguino PAC-210 Air Conditioner
Can you Help with these Air Conditioners problems?
Repair Service
Find Air Conditioner Repairman Near You:
