Question about Sanyo DS25390 TV
White lines on picture
Have about 3 inches of horizontal thin, white lines at top of picture--is there any adjustment to get rid of this?
  • cmomm Jan 27, 2008
    thanks--to both-----it is a Sanyo DS25390----probably cheaper to ditch it than repair, especially with HDTV coming up this yea???your thoughts?
  • 934 Answers
More specifically C516 4.7uf/50v, C507 220uf/35v and las but not least C502 220uf/35v Change them all for greater reliability.
Bill
Posted on Jan 27, 2008
  • William Rayburn
    William Rayburn Jan 27, 2008
    Cheaper to fix it and you'll get a coupon for a converter through your local post office... Caps wil cost all of about $4.00 dollars and if you're half decent with a soldering gun it shouldn't take but about 15 minutes - and most of that just getting the back on and off... Just make sure you put the new cap in the same way the old came out, they are polorized..
    Bill
  • 2,336 Answers
There aren't any adjustments to be done for this issue. The only way to fix it will be to replace a low capacitance electrolitic capacitor(s) in the vertical section of the TV. The capacitor value may be below 100uF depending on the brand of TV you have.
Hope this helps.
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Solid thin horizontal line
Check for excess screen voltage. Adjust the screen control to eliminate these vertical retrace lines. [Thin white line acorss the frull screen at about 1 inch apart.]
Mar 10, 2012 | Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Horizontal white lines on top of screen
try to adjust the screen control in the flyback transformer. good luck
May 04, 2007 | Panasonic CT-27G14 27" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Televison & Video Logo
90 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
