Question about Garmin Nuvi 350 Car GPS Receiver
I dropped my garmin nuvi and the power button is jammed in...am i hopeless?
  • 3 more comments
  • oelonade Dec 16, 2008
    my nuvi 350 no sounds and its full volume
  • dave247365 Jan 06, 2009
    I have dropped my Navman and now it still works but it has no reception from the satellite , any ideas?
  • Anonymous Jan 06, 2009
    where is the best place to send unit? I have a Garmin NUVI 350
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    There is a plastic pin inside the case that limits how far the on/off flap goes down. It would appear you have gone past the pin and the flap has jammed.
    Please contact me if you would like for me to repair this problem on your unit.
    KS3R at sharc dot net
    - Jim
  • SHARCNET-USA
    Please give me more info so I can help you.
    - Jim
  • Garmin Master
  • 638 Answers
There is a site where you can send your unit for repair. http://www.sharc.net/gps_repair.htm I am in no way affiliated with this site.
Good luck.
Posted on Jan 10, 2009
Try to use a dental tool (small hook-pick) to pull it back out, otherwise send it back for repair.
Posted on Feb 19, 2008
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
Garmin nuvi 265WT keeps turning on and off and does not go any furhter
Check to be sure the nuvi has a fully charged battery or is connected to a power source.
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Sep 23, 2011 | Garmin nuvi 265WT Car GPS Receiver
When turn the Garmin on it gets the the screen that says Garmin and shuts off
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 1350 LMT turns on to a calibration screen. it will not go to the maps home screen. how can i fix this
There should be a black dot to press on the calibration screen. Keep pressing the dot as it moves around the screen, you may need to press very firmly and use a stylus until it says calibration complete.
This usually occurs when a unit is dropped or left in extreme temperatures or jammed it a glove box or console with things jammed against the screen. It could also occur if you are touching the screen as you start.
Thanks for using FixYa
Jul 27, 2011 | Garmin GPS
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
Ok so my Garmin nuvi 1300 is frozen the screen and power button doesnt help fix it at all either and i need to know how to fix it please
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 11, 2010 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 1300 won't turn on. It should be fully charged as I drove a couple hours with it plugged into my cigarette lighter. Nothing happens when I push the power button. I've had it for not even a...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Dec 28, 2009 | Garmin nuvi 1300 Car GPS Receiver
NEW GARMIN MISSING SOTWARE MODEL NUV1 200W
I did exactly the same thing!. This is how I fixed it.
Use Updater.exe NOT WebUpdate. Download the latest firmware for your unit (the rgn file), then connect your nuvi via usb. Turn it on and hold the power button left, at the same time drag and drop the rgn file onto the Updater,exe. It will start automatically and reload the firmware over the corrupt one.
Here are the files:-
http://e-trex.info/fw/nuvi/2x5w/fw_nuvi2x5W_ID0827_en_v460.rar
Enjoy
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
146 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
