Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer and scanner not working
My printer and scanner not working some error showing as:
Cannot scan for these reasons:
- The original may not be set correctly
- The Protective Sheet may be put in place
- The lamp may not be warmed up
(It needs a few minutes for adjusting lamp on a low temperature.)
Scanner driver will be closed
Code error - 2,178,0
  • bengan13 Feb 01, 2008
    I have the same problem on my Canon PIXMA MP810
  • dfeltus Aug 30, 2008
    I have the same problem with my MP810. I have reinstalled the scanner driver MPNavigator 3.03. Same problem. Problem started after I scanned some slides. Scanner works in local mode - both for copies and for scanning and downloading to the computer.
  • 27 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
588
Posted on Feb 27, 2009
  • 96 Answers
Can you do photocopies locally...?
I so you can ignore the above mentioned messages...
I would reinstall the scanner software and verify all cable connections.
Posted on Feb 10, 2008
2 Suggested Answers
SOURCE: Canon PIXMA MP160 problem
i need help getting this going
the error button keeps blinking htis is an new scanner printer
the alram button is blinking on and off
Posted on May 25, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
What's my problem?canon pixma mp287 do not work for scan
i have a canon pixma mp 280 printer . when i set paper in scanner and click ok then error shows printer to use on error and scanner driver close.please sir help me
Apr 15, 2012 | Office Equipment & Supplies
I have find the error in printer canon lbp 2900 scanner error
First of all you are not sure about your product and problem
When LBP-2900 is only a printer.
No any other combination is present
No scanner OR Copier
May 12, 2011 | Canon LASER SHOT LBP-2900 Printer
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scanner Error
Some electronic equipment such as printers and scanners need to be "calibrated".
I recommend you follow the directions and allow the Scanner to calibrate. This may result in better scans and for printers, better printouts.
Mar 30, 2009 | Kodak I660 Flatbed Scanner
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My printer show this code 2 E 7
I have problem with my scanner.
when I want scan whith that show this message:
cannot communicate with scanner
cable may be disconnected or scanner may be turn off.check status.scanner driver will be closed. code : 21550
please help
Jun 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
264 people viewed this question
old marine
old marine
