Question about Intel D865PERL Motherboard
Installing 2 Ethernet Cards
I have tried to installed to ethernet card with my D865PERL. The first was CNET PRO200WL PCI Fast Ethernet and the other one is D-Link DFE-528TX 10/100Mbps Fast Ethernet Adapter, after installing the both together with its drivers, i can boot on windows but after a while it hangs. I tried to restart it but it's still the same. When i tried to uninstall the D-link my system does not have problem. Is their anything that i should configure with its BIOS so that i can use two ethernet cards?
  • brianjan Jan 30, 2008
    I wanted to connect both my pc with internet and share files.
    Problem Solver:
  • 29 Answers
A bad driver for the dlink? any reason for using 2 NIC's?
Posted on Jan 27, 2008
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Swann network card
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
http://download.cnet.com/realtek-rtl-gigabit-and/3000-2112_4-10278840.html
http://download.cnet.com/cnet-pro200wl-pci-fast/3000-2112_4-20682.html
hope this helps
Sep 13, 2012 | Computers & Internet
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
Network card cnet pci-bus adapter without drivers for linux pleas
Install the drivers that came with it. it's usually comes witha CD. If not, download the drivers from cnet website. After you install the drivers turn off your computer, open the cover of your CPU and plug the adapter on any available PCI slot. When your restart your computer the card will be detected and drivers will b e installed automatically.
Jun 08, 2009 | Cnet : 10/100 PCI FAST Ethernet Card...
One of two 3com pci gigabit ethernet cards is not working
If you have the driver disk that was distributed with the card , try reinstalling the card drivers first.
If the card is faulty, buy a new pci ethernet adapter and replace it, inserting the ethernet adapter into the pci slot.
After installing install drivers for the new card with the disk that will come with the card.
Ensure that you are logged in as administrator when you reinstall the drivers.
Nov 05, 2008 | SysKonnect Gigabit SK-9843 Network Adapter
Intel D865PERL Motherboard Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
