My samsung hlr6167w shows a striped or plaid screen when using the av cables or the antenna jack. The only picture that comes in clear is through the hdmi. Why wont any of the other jacks work correctly?
jbarber437 your comment would be more useful had you supplied the part number for the digital converter circuit modulejbarber437 your comment would be more useful had you supplied the part number for the digital converter circuit module
You can't post conmments that contain an email address.
Bring up your video menu, make sure the cable/antenna mode is set correctly. Also do channel search/ auto program. If your AV is operating a DVD player etc., there should be a button to switch from TV to AV. If you are trying to input Cable/Antenna to AV jack you may have it plugged into wrong jack, it should go into 'antenna/cable in' jack. Hope this helps.
Are you able to access the on-screen menus (like brightness/contrast etc)?
If those menus are appearing over the green screen, then it might be a cable or image source problem. I've often seen this green screen when the HDMI encryption between my cable box and my TV gets messed up. Only solution has been to power cycle the cable box.
If you can use something other than an HDMI cable to connect your TV to your picture source, I suggest trying that and seeing if you can get SD channels again. If you do get them back, it was a cable issue. If you still can't get them, contact your cable/satellite provider, see if there's something up with their signal.
You need to do an aggressive reset on the TV. This solved problem
completely for me. You must unplug the TV when it is on. Repeat this
several times until the TV is jolted back into the factory default
settings. The issue is actually with the programming I believe. The
clue was that the display worked 100% perfect in HDMI mode, and the
problem only existed in the cable setting, no matter if wires were
attached or not.
Again, do an aggressive reset to the TV by unplugging it several times
while it is on. It may not register the reset at first because after
all, the actual problem is a programming issue and it's having trouble
recognizing commands in the first place.
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
attached or not.
If you are using cable and the signal is connected to the TV through the regular cable wire, then the TV must be in TV mode to work properly. If you are using a cable box with that TV then the TV must be on channel 3. If the screen shows AV 1, then the TV is in the AV mode (red, white and yellow RCA jacks), and you most likely accidently hit the INPUT button on the remote. Pressing 0 3 or INPUT a couple of times on the remote should bring your picture back.
The following describes the symptoms, cause and prevention of the Moire effect.
Symptoms of the Moire effect
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image.
An example of this can be seen in the pictures below.
The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left.
This effect is called the Moire effect.
Why does the Moire effect occur?
Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect.
Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect.
Preventing the Moire effect
You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
