Question about SanDisk Sansa e260 MP3 Player
Sansa e260 screen not working
The blue light on the turn dial will turn on, but the screen shows no signs of life. I attempted the recovery mode, with no results. It is only a few months old. Please help :)
  • Nurze4kidz Feb 02, 2008
    Yes. The dial stays on and won't shut off. I can get it to shut off by holding down the power button, but as soon as I hit the power button again, the dial lights up again.
Reset your mp3 while holding the power button over 15 sec.
Posted on Jan 30, 2008
I need a answer to this as well because im having the same problem the dial lights up but the darn thing wont turn on ... this is my 2nd e260 and i have did 1 update so far it wont even allow me to go into recovery mode so im at a loss of ideas!
Does the dial stay on and won't shut off?
Posted on Jan 27, 2008
  • villeluva
    villeluva Feb 02, 2008
    this might help...
    leave it alone until the battery runs out and the light shts off. then recharge the battery fully. the same thing happened to me and that was the first thing i tried.
    hope it helps you
My sansa e260 says load main screen fail switch to recovery mode...what do i do?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa.
http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related
here is a link to a kid showing you how to go to recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Usb mode in settings MSC is best, Updater recognizes it in this mode
Jun 26, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 volume will not work?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Mar 10, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e260 just stopped working :( I tried the
Try inserting a(n) SD chip into the player and then try restarting. If it gets stuck on the refresh database screen, plug it into your computer. It's the only thing that unfroze my e280.
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 screen wont turn on anymore!
try to get a driver for the mp3 for the computer, and check if the battery is okay.
Jul 26, 2008 | SanDisk Sansa e260 MP3 Player
Kashif
I had the same issue I think to switch to recovery mode you lock the keys and hold the record button as you turn on the player. The only place I know of the get the firmware is the official website.
Jul 13, 2008 | SanDisk Sansa e260 MP3 Player
Blank Screen
try letting the battery run out than plug it into your computer and see if that works
it sounds dumb but i had a similar problem and it worked
Mar 28, 2008 | SanDisk Sansa e260 MP3 Player
Help! Sansa will turn on, go to the opening 'sandisk' screen and that's it
go to sandisk website and download a firmware updater
for your sansa e260
Oct 20, 2007 | SanDisk Sansa e260 MP3 Player
My Screen/LCD does not work!!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e260 MP3 Player
No screen
Sounds like the blue ring issue. TRY THIS FIRST!! If it works then great, ONLY DO THE LAST SOLUTION (a link) IF RECOVERY STEPS BELOW DO NOTHING. You WILL brick your sansa if you don't abide. In case our recovery procedures differ: ALL DATA WILL BE LOST WITH THIS PROCEDURE!! You can try a ROM recovery. - TURN OFF UNIT - Place hold switch so orange shows - Hold down the REC button with the red dot on the side of the player. - Whilst holding the REC button, press the power button as if to turn on the unit - Let go of the REC button You should see the recovery console. YOU WILL LOSE ALL DATA!! However you will also have a working player. LAST RESORT ONLY IF YOU CANNOT ENTER RECOVERY MODE!! http://www.anythingbutipod.com/forum/showthread.php?t=8953
Aug 18, 2007 | SanDisk Sansa e260 MP3 Player
It wont turn on
I would like to offer this solution, but this solution is only meant for the "Standard" E200 players (there are 2 types of E200 players -- the Standard E200 and the "Rhapsody" players, indicated with an "r" after the E200 such as "E260r". I'm hoping you have the standard E260. Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E260, just like I do. (I love this player)
Apr 20, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
115 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
