Question about Acer AL1716 17" LCD Monitor
Snowy Raster on display
Im repairing a acer lcd al 1716 17 inch monitor the problem is ther a snowy ruster on screen but the menu display is ok
  • 1 more comment
  • Marc Cuyag Jan 31, 2008
    Tnx.,
    but i already do that u said, doesnt work.
  • Marc Cuyag Feb 02, 2008
    yap i also try configure the osd and video diasplay setting. but doesn't work.
    my last option is a video chroma microchip ic to reheat.
    tnx.
  • Alexandre D Jan 14, 2009
    The superior side of my 17" AL 1716 after some hours of use becomes "marked" with the previous screen. Usually, this happens with programs such as browsers or MS office that have a static superior bar. When I minimize,change the screen or start other programs, is visible that bar is still there in a whitish blured stile.
    I've tried to reinstall the driver of the monitor but it didn't change nothing..
    Novelist:
  • 103 Answers
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Posted on Jan 30, 2008
  • Rosener Guyano
    Rosener Guyano Jan 31, 2008
    your welcome. have you also try setting the video properties in operating system control panel and set to higher resolution and color quality and select other frequency rating. l met this problem before, lcd on Asus desknote by setting then it works fine. If the problem persist there something wrong with the video processor circuit. Have a nice day!
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Thanks,
Jason
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Snowy screen
Hello try to renew the graphic driver from here:
http://support.acer.com/product/default.aspx?modelId=3658
If the driver does not help, the screen must be renewed.
A pc repair shop can help you with that.
Good luck
Jan 26, 2013 | ATI Acer Aspire One 722 Netbook...
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
NEC 17"1700M Works fine most
Either an overheating video-card, or a loose connection between the video-card and the monitor.
Jun 25, 2011 | NEC MultiSync LCD1700M (White) 17 in. Flat...
Radiation lines scroll on monitor screen
Check and jiggle (yes, that's the technical term) the monitor cable at both ends to make sure the connection is tight. If this doesn't help, borrow a cable from another computer (or a friend) that you know works, and use that to connect the monitor to the computer. If the picture is no longer snowy, you have a bad cable; buy a replacement one from any number of dealers (I recommend http://www.discountcablestore.com/, they're just about the best prices anywhere, but if you don't feel comfortable ordering online, any store with an electronics department should have one.)
If it is still snowy, try plugging your computer into a different monitor and see if the picture is still snowy. If it isn't, then your monitor has probably gone bad; check it's warranty, and consider buying a replacement.
If it is still snowy, post back here with the name of your graphics card (in Windows, this can be found by pressing the Windows key and the R key at the same time, then typing in 'dxdiag' without the quotes, hitting Enter or OK, and looking at the 'Display' tab of the window that opens. If a warning message shows up about it being run for the first time, click OK or Yes.).
Mar 01, 2011 | Samsung SyncMaster 152 (Silver) 15" LCD...
Monitor screen is snowy and has a vertical bar 2
This could be either your screen is failing or your grahpics card
Jul 04, 2010 | Sony ® VAIO® V TV-PC Series -...
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
Display problem
sir,mam you need to check first your cable connection for proper ground,maybe insuficient grounding on your cable and that why your reception signal become snowy.
Aug 29, 2009 | Philips 107E61 17" CRT Monitor
Acer AL1716 17" LCD Monitor Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
