Question about Maytag Atlantis MDE7400AY Electric Dryer
Timer/sensor problem My dryer won't automatically shut off using either the timer or the sensor to tell when the clothes are dry. It does not chime when the clothes are dry and the only way it will shut off is if we do it manually. Not a big problem but if we ever forgot to shut it off, it would be a definite fire hazard. Also I have heard that you are supposed to open the dryer up and clean the lint from the inside to avoid fires especially around the elements. What is the easiest way to do this?
    President:
  • 878 Answers
If this is a intellidry model, sloped front there is a couple of things you want to check. The problem lies in the electronic control or the sensor bars. You would have to disconnect the wire from the sensor bar and run the dryer. If the dryer runs for about 20 minutes and shuts down or the timer advances then the electronic control is good. The problem lies in the sensor bar, inside the drum. Clean the sensor bar with alcohol. Fab softner can build up on these and give a false reading. To get to the inside of this, you will have to remove the door hinge screws, the door will lift up and off. Then remove the spacers on the other side . The front panel will now pull out and off. From there you will see how to get at the sensors. Catriver
Posted on Jan 27, 2008
Dryer does not shut off when using Sensor Drying. It just continues to spin until someone turns it off. Any advice would be appreciated, thank you. Steve
Could be a timer issue but more likely a temperature sensor issue. The temp sensor operates from within the dryer. If you look inside the door of your dryer, there will be two metal bars towards the front. That is the temp sensor. It's job is to detect wet clothes on the automatic cycle by way of moisture from the clothes causing continuity across the sensor, in turn completing the circuit to the timer, thus telling the dryer to dry. Hope this helps. Also, you may check your vent.
Jul 16, 2015 | Whirlpool Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Dryer won't shut off automatically
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
Aug 05, 2009 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
My Kenmore Model# 110 66652500
See the following hints from Repairclinic:
If it does not heat up, the element can also be faulty.
If you need to call a technician there is a phone number listed at the end of the user manual.
Sep 04, 2008 | Kenmore 63012 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
329 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
