Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Side-by-Side Fridge
How do I remove the doors on my side-by-side Whirlpool fridge, so that I can fit it out the front door when I move this week? Is there anything I should know about disconnecting the water line that runs to the door of the fridge??
  • 770 Answers
Unscrew the cover plates on the top door hinge there are quick connects for the elects and 3 bolts on the freezer side and just 3 bolts on the refg side before you removed the freezer door pull the kick plate and there is a water line quick connect you will need to disconnect it as the tube runs thru the hinge after the top bolts are out pull up on the door and it is off >>>Note: there are some small plastic washers on the hinge post make sure you dont lose them
Posted on Jan 27, 2008
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
Side by side fridge door adjustment
Good day,
There is a complete warranty on the machine and cabinet for the first 12 months. The selling dealer should supply you with a free warranty service call.
There are variences allowed for such things by the manufacturer, but they should make you whole.
Contact the dealer first.
Jan 12, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Maytag american side by side fridge freezer need to remove doors.
1st turn the water to thefrige. then disconnect the water line (front left bottom) then remove the caps from the top then remove the three screws on each side holding the hinges. with the door slightly opened lift straight up. then do the other side
Dec 08, 2009 | Washing Machines
Want to move whirlpool american side by side fridge freezer but need to remove doors how is this done
1. If you just need to gain a little space you can simply remove the door handles. They should just lift (or slide) up with moderate force and can be removed.
2. If you only need to move through one door in a building you might be able to open the doors enough to make the unit clear the door you are trying to move the unit through. This would take care.
3. If you really do need to remove the doors, be sure to disconnect the water line at the rear. Then gently snap off the hinge assembly covers at the top of the unit and disassemble the hinge. Be aware of water lines when you are ready to remove the doors.
Jul 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
Dec 17, 2008 | Whirlpool GB2SHDXP Bottom Freezer...
Getting Doors off of a side by side fridge
hi thanks for the question the caps on the top come off remove the screws the electricals usually disconnect remove the door thanks for the question please accept a positive feed back is nice thanks the appliance doc
Sep 23, 2008 | Whirlpool GS6SHAXMQ Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
161 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
