Question about Yamaha LPX500 Multimedia Projector
Yamaha LPX 500 home cinema projector isn't lighting up
My yamaha LPX 500 projector is turning on (green light comes on) then after a short time the system switches to red and turns off. I replaced the lamp about a year and 1/2 ago. I also cleaned the filter. What else should I do before calling a repairman?
  • Anonymous Oct 11, 2008
    exatcly the same problem ... did you need to get it fixed?
  • Dr Suess4769 Jan 02, 2009
    i have had the same problem and at first i changed the vent thinking that it was overheating
    HOWEVER
    when this problem occurs the projector tells me via its light notifiers that the lense cap is on when that is clearly not the case
    i found that if you take the bulb out and place it carefully back in then it will reset all of the sensors and you should be good until the next time it happens
    its a short term fix but it does work
The reason for a red light is replacement of lamp or it is running too hot. Have you checked for proper venting, and cleaned them recently. The bulb usually lasts 2000 hours, so you may need another.
Posted on May 02, 2008
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
What should i do when my projector's temperature light is flashing red 30 sec after start up?
try changing the light bulb. they have a time limit on them. with mine, I had to change the light bulb. Not cheap, but it worked for me.
Nov 12, 2014 | Epson PowerLite Home Cinema 8350 3LCD...
Blue light flashes, lamp doesn't light
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Lim
Mar 04, 2014 | Epson ELPLP69 - V13H010L69 Projector...
My YAMAHA LPX-500 projectors start up logo remains faintly visible constantly during operation-any answers?
Hello sounds like you have the logo screen burned into one of your LCD panels. This will be a very expensive repair, seen as the LPX-500 is only an 800 lumen projector, it would be a good time to look for a replacement. I would not recommend spending any money on this unit.
Hope this helps
Projector Guy
Mar 31, 2010 | Yamaha LPX-500 LCD Projector
Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Jul 15, 2009 | Office Equipment & Supplies
Yamaha LPX 510
Welcome to the disapointing world of LCD projection. Your blue device is dying and thus allowing the green to come through instead of combining for white. I suggest buying a dlp product they are immune to this color decay problem. Good luck
Jan 13, 2009 | Yamaha LPX-510 Multimedia Projector
How to connect laptop to lpx-510
VGA cable or S-Video if your projector has a S-video port
Hope this helps
Nov 14, 2008 | Yamaha LPX-510 Multimedia Projector
Does not display the color blue?
lamp replacement will not solve your problem. The problem is with the main board or RGB Panels.
Viren
Nov 24, 2007 | Yamaha LPX500 Multimedia Projector
Yamaha LPX500 Multimedia Projector Logo
407 people viewed this question
Top Yamaha Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
mitch_3020
mitch_3020
Are you a Yamaha Office Equipment and Supply Expert? Answer questions, earn points and help others
