Question about Minolta EP1083 CS/PRO Copier
Malfunction code My copier stopped working and is now the little wrench is lit up and a code of C0500 is in the zoom display. Any idea of what that code means, and if I could fix it myself?
  • Minolta Expert
  • 1,326 Answers
C05 is a fuser code, it is reading a wrong temp. of the fuser. You can try to reset it. It could just be a power surge.If u want to try itis easy. Turn the power "off" and unplug the "adf" if so equiped. Open the front door and open the claim shell as if to remove a paper jam. Then remove the 3 screws( #2 phil) from the top back cover and remove the top back cover. Turn the power back "on" with the copier still clam shelled opened. On the back of the copier u will see the DC controler with a "white" plastic box on it. Right below that u will see a small "Black" botton, push it and it will reset the code. Close the copier back up and see if it come up to ready and make a copy. If it codes out agian open the clam shell and feel the fusing ass'y is it warm or cold? If it warm it could be a bad thermister or if it is cold it could be the thermal fuse or the fusing lamp is bad. If it dose not rest you need to call a copier repair company...... Make sure you put the covers back on and close the copier up and let the tech see the code.
Posted on Jan 30, 2008
C0500
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 01, 2014 | Minolta Di3510f Bizhub Copier
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
How can i reset my konika minolta 162 to function well which is writing service call and a code C0500
C500 fusing unit malfunction.Look at a liitle holle on the right side on display.Press the microswitch and wait will apeire * and press 3 and press trouble reset.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Code c0500
C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
Oct 18, 2013 | Konica Minolta bizhub 161f All-In-One...
Malfunction code c0500
In minolta copiers the C5xx codes refer to fuser unit malfunctions.Verify the fuser unit gears,the fuserheater lamp continuity and the thermofuses continuity.To reset the codes please the copier model and I tell you the reset method.
Mar 01, 2013 | Konica Minolta Office Equipment & Supplies
C0500 error code
Verify the continuiti of the thermofuse and the heater lamp,cleaning it reset the malfunction codes to open /close the front door or enter in the service code Stop-00-Stop-01,acces 3 after appaire the * in the left side in the touch pannel,reset to trouble icons,press exit and total reset button twice.
Dec 07, 2009 | Konica Minolta DiALTA Di200 Copier
How to reset malfunction code C0500 of a imagistic im2020 copier
On the side of the control panel, there is a little hole, use a paper clip unbent to press the switch inside hole. The touch screen will restart. watch the left hand side 2/3 up, a little dot will appear, when it does, press 3. The login in is all zeroes. press trouble reset and then turn off and on using the switch at the left side, lower back edge of machine.
Nov 06, 2009 | Office Equipment & Supplies
I'm getting a malfunction code C0500
C0500 is a heater failure, the fuser section failed to get to the desired temp in a given period of time.
Try resetting the code, there is a reset switch behind the access panel,at the contrast knob inside the machine.
Hope this helps.
ed
May 04, 2009 | Konica Minolta Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
118 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
