Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore side by side
Lights come on when door is open, but completely quit working. Electronics display inside refridge are off.
  • gbhdoc Jan 27, 2008
    Clarification, the interior light comes on when each door is open. However, the control board panel is off and the unit is obviously not running. So I know there is power; can the control board be reset somehow?
    Scholar:
  • 72 Answers
You need to elaborate more. If it's just the light quit working, then check the bulb first, if it's good then use a meter to check if you are getting power to the socket (red lead to middle contact, black one to the metal ring) check with meter on ACV at setting 200 or so and it should read 110-121V. If that's good then keep backtracing until you find the problem.
Posted on Jan 27, 2008
  • Andrew Boulware
    Andrew Boulware Jan 27, 2008
    The light's usually on a separate circuit than the control circuit, that's what I was trying to get to. Have you checked for fuses on the hot line into the control board? If there's not one on the board itself, then check for a knot in the wire going up to (look like a cylinder) and take two sewing needles, with the unit unplugged stab one on each side of it and check continuity, if you don't get it get a replacement inline one of same value and check it again.
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
Unit not running, no lights on pannel but lights work inside.
Could be a control board issue, a broken wire somewhere, maybe the plug came off of the board. Try to unplug the refrig and plug it back in....A lot of times that will reset the board
Sep 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator door doesn't close good
Hi there check that the door hasn't been pushed open too hard and stressed the hinge area,and if so try carefully tapping the hinges back.hope this helps.
Dec 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Refridge and freezer stopped cooling
it is either the start switch on the side of the compressor or the compressor itself.
the buzzing sound is the start switch trying to start the compressor and the click is the overload on the start switch kicking it out.
the start switch is bad or the compressor is pulling too much amps = bad compressor.
Jun 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana French door Refridge-water dispence inside the door not working
pull out crisper and deli shelf thers a tank behind them its probably froazen, hit it fora few minutes especally around top neck portion with a hair dryer, common issue
Jan 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Smell coming from the refrigerator
I would assume you have a bad self defrosting motor. This motor generally is used to cycle heat at certain points to keep the unit from allowing the condansation from freezing inside the refridg. I am assuning the smell is this motor heating up. Should the motor quit, it is normally not a fire hazard but should be taken care of. You'll need to remove the back panel of the refridg and you'll see the minuture motor and probably hear is making noise. Always be sure to unplug the refridg before opening the back panel or any service to prevent shock. Good luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
