Tv lack of horiz. width
I HAVE A OLDER TV WITH A LACK OF HORIZ.WIDTH, IT HAS ABOUT TWOINCHS OF BLACK SPACE ON BOTH SIDES. CAN YOU HELP. THANK YOU.
  • bigghee Jan 31, 2008
    HI! THIS IS BIGGHEE AGAIN , MORE INFO. THIS HAPPENS ON ALL
    INPUTS. I THANK THAT I HAVE NARROWED THE PROBLEM DOWN TO THE Z
    BOARD WHICH IS THE PIN CORRECTIONS CIRCUIT THIS HAS TO DO WITH THE
    SCANNING OF THE OUTER EDGES OF THE SCREEN. I NOTICES IF I PULL THE Z
    BOARD OUT OF THE CIRCUIT ,THE SCREEN FILLED OUT.SO I REPLACED CAPS. AND
    THE THREE TRANSISTORS ON THE Z BOARD AND THAT TOOK CARE OF THE
    PROBLEM . THANK YOU GUYS FOR YOUR HELP.
  • Alan1962 May 11, 2010
    Is the picture coming from the TV's analog tuner, from a dvd player or from a digital set top box?
  • 149 Answers
Hi there, lack of horiz. width means horizontal section problem, test some electrolytic capacitor at horizontal section and try video section. ty
Posted on Jan 27, 2008
Broad black strip on left side of screen. Is this a horizontal fly back problem and where do I look first?
Less width is the problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 10, 2015 | Zenith B27A11Z 27" TV
Screen Adjust
You can't. There are no adjustments for height and width. Not all programs were shot on 16 x 9 wide screen resolution so it will leave the screen with black spaces . around the edges. Nothing wrong with the TV, and nothing you can do other than the zoom buttons you use now.
Aug 09, 2017 | Sanyo DP19648 19 in. LCD TV
What is cost of yoke for panasonic ct tv?
You're discussing about the width problem to picture. If yoke have a short in between its wingdings [even a single winding short], will cause the failure of horizontal output transistor. As per you report here, the set has a raster, but problem is with the picture width.
There possibliliites for this fault are.
1. Lack of voltage from the SMPS power supply output.
2. Horizontal width capacitor.
3. Horizontal output capacitor.
Check the output voltage from the SMPS section first, and confirm that it is OK.
Jan 03, 2013 | Panasonic CT-24SL13 24" TV
I have 2 black spaces on each side of my screen
The width of the picture is less than normal. It can be adjusted by entering in to its service menu options. But, entering service menu options and adjusting data values there is a skilled task. It will be best to contact any expereinced service techinician ot do this. Or Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. If you are confident that you can do this, just proceed. If not, do not tamper the TV.
Aug 05, 2012 | RCA F27450 27" TV
Exact Outside Width Of The Ge Jx2127sh Microwave Trim Kit. Does anyone know the exact total width of the GE JX2127SH Trim Kit? None of the GE sites list the outside width.  Extrapolating from the cutout...
I would go with it. The 1/8" on each side you are worried about can probably be trimmed if need be. The manufacturer is usually very precise on an measurements they publish.
Dave
Jul 04, 2017 | Microwave Ovens
Solid 2 inch black line from top to bottom
Your tv has a vert. circuit that controls your pic from top to bottom.It also has a circuit that controls the pic from side to side.Your horiz.(side to side) has collapsed.
Sep 25, 2010 | Panasonic TH-50PX75U Plasma HDTV
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace...
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Oct 19, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
27'#27pts5441\37 serial#ya1a0505010585
Model # 27PT5441/37 needs Horiz Driver Kit ( L04.1U chassis)
Part # 483531057673 and replace 47mf/25v capacitor in horiz drive circuit....................................T.
Nov 22, 2007 | Philips Magnavox 27MS343S 27" TV
Panasonic 32" picture reduction
IT IS LESS WIDTH PROBLEM It has to be done by tech person as inside tv high voltage is thare so unskilled person should not open tv. problem is simple. 1 less output from regulated power supply . 2 if width control is there it can be done by that.
Sep 17, 2007 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
