Question about Samsung Digimax D53 Digital Camera
Camera wont turn on
When you turn on the camera it beeps 3 times and wont display any pictures or you cant take any picures
  • 2 more comments
  • Anonymous Mar 04, 2008
    turns beeps three times then shuts off
  • 123one Mar 19, 2008
    same with mine! i droped it abou a foot from my desk and it landed on carpet but i tried to turn it on and it would turn on for half a second and then make 3 beeping noises. I went onto google and typed in my problem and someone on one of these things said to fix the lence if it was not strate. mine was not. i poped it back strate but it went back into the camer a little bit further, i pressed the on button and it turned on but then turned right back off! some one please help me!!!!!!!!!!!!!!
    i even tied changing the batteris and i have chaargeabe ones!!!!!
  • Anonymous Apr 07, 2008
    I also have the same problem, I turned camera on, to take pictures, turned itself off, and the lense stuck half way, changed batteries, light comes on, goes off, and makes 3 loud bleeping noise
  • Anonymous Jul 27, 2008
    same problem but my lens is in the whole way i beeps 3 times and wont even aculay show u what is in front of you HELP!!!
    Problem Solver:
  • 5 Answers
The camera may in fact be hung in voice recording mode, or may in fact have a low voltage error or internal failure. Suggest that you follow this routine. 1 remove batteries and press the on button, nothing should happen. Allow camera to sit for five minutes. 2 remove memory card if one is installed into camera. 3 install two fresh batteries in camera and attempt to power it on. 4. once on set the time and date. attempt to take a photo. then cycle the camera off. Once again power it on and see if the settings remain intact. If it is working then power off and insert the memory card and test again. I have found that allowing the camera batteries to run low and die in the camera cause a series of problems like the one that you have. Always use rechargable batteries of the Nickel metal hydride construction in this camera. This is the only known reliable power source for this camera. Note: camera instructions for this model can not be found on the samsungusa site and you will have to go to to find instructions for this older model.
Posted on Apr 06, 2008
The beeping noise and automatic shutoff happens in two cases. Either the batteries are dead and it won't turn on, or the lens is stuck. My batteries were fully charged and it still wouldn't turn back on, so I tried moving the lens and it clicked back into place. Put in charged batteries and now it works fine.
Posted on Apr 30, 2008
The screen just wont turn on. i turn on the actual camera but no picure shows on the screen
Try to shoot a picture and download to pC. If it is ok then your lcd is bad. You need to replace it.
Mar 20, 2011 | Canon PowerShot S50 Digital Camera
Cant set time
once you turn your camera on, press the buttton that displays your pictures. once your pictures are being displayed, go on the menu. at the top of the menu, there are 3 tabs. go to the second one. in that minormenu, youll find the icon "set time".
Oct 08, 2009 | Cameras
The camera turns on and seems to operate normally but the lcd display is black and the pictures are black. If I review older picures the lcd display is fine.
Time to clean the battery slot. Take a Q-Tip "dampened" in rubbing alcohol and clean the battery contacts within the compartment. Be careful not to snag the small battery ejection spring toward the outer edge. It a good idea to wear a magnifying headset while doing this. Do the same to the battery and the charging station.
Sep 07, 2009 | Canon PowerShot A530 Digital Camera
Wont take a picture unless I turn off the flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Picures wont upload :X
go to my computer it will say your cams name cick on it
Dec 08, 2007 | Samsung Digimax D53 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax D53 Digital Camera Logo
173 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
