Question about Microwave Ovens
Kitchenaid model KHHS179LSS Microwave oven handle replacement
How do you open the back of the door to get to the handle screws?
  • 4 more comments
  • Popsracerx Feb 11, 2008
    I need to replace the door handle on a GE spacesver model #JVM130K. How do I get to the screws that hold the handle on? Thanks.
  • tn12 Mar 08, 2008
    I have the GE JVM163 microwave. I am able to open the rim around the door and expose two of the four screws from the handle. I don't see how I can get to the two bottom screws behind the inside door. Can you give me some insights how to expose the other 2 screws? Thanks in advance for your advice.
  • Rick Wright Mar 10, 2008
    I have a Dacor PMOR30S above range microwave with a broken handle. I have no idea how to get the door apart to change it. Any ideas?
  • Anonymous Jun 02, 2008
    I can't get to the screws to replace the handle on my kitchen aid microwave oven.
  • Anonymous Nov 08, 2008
    Did anyone have any luck with replacinng the door handle? Having same problem with finding how to gain access to bottom screw on microwave door. Thanks.
  • Anonymous Mar 14, 2014
    Kitchenaid microwave oven has no power. Model: KHHC2090SBL1
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Posted on Feb 06, 2008
For the Dacor PMOR30S, bthompson is correct on the door removal. If you can't get the door to "remove", there is a small plastic panel inside the door at the top hinge. Just gently pry that loose with a small screwdriver. It will expose the top hinge and you will see how to lift the door out. After the door is removed, you must remove the rectangular plastic panel inside the door. Start at the top hinge and gently pry the panel loose. it makes lots of cracking noise coming out but it is [generally] not breaking. I cracked mine near the top hinge, but it stayed in one piece and it reinstalled easy. Note there are not two screws on the edge of the door as bthompson describes above. But after the rectabgular panel is removed, it exposes the two screws that hold the door handle. Just remove those and all broken plastic debris. Then install your new handle. Be sure to tighten the two screws on the backside of the new handle before you install it (they may already be tight). Also note that the handle can only be installed one way - you can't flip it top to bottom. Tighten the handel screws, gently reinstall the rectangular panel, reinstall the door, reinstall the small panel at the top hinge. You're done.
Posted on Nov 09, 2008
I cant get the screws out of the back of my microwave how do i go about this
Magnetic screwdriver with extended shaft.
If you have chewed the screws get a screw removal bit and use a torque driver.
May 13, 2014 | KitchenAid KHHS179LSS Convection /...
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
Jul 03, 2010 | KitchenAid KBMS1454RSS Microwave Oven
Microwave exaust fan starts on its own
There's a humidity sensor in this microwave oven that turns on the fan automatically if it senses an excess amount of humidity (steam from cooking for example) to possibly protect humidity or moisture from building up inside the unit.
Apr 01, 2010 | KitchenAid KHHS179LSS Convection /...
Replace the buttons on a kitchenaid microwave Khhs179lss-5
First, you need to uninstall the microwave (MW) from the cabinet by removing the screws that hold it in place at the top. Open the cabinet doors above the MW to locate the screws.
You will need someone to help you at this point in removing the screws and dropping the MW down. Be sure and unplug the MW before you remove the screws.
Next, you need to take the cover/shell off by locating and removing screws A/R. They are mostly across the back and side bottom.
From there on out, you should be able to methodically find and locate the various fasteners that will get to the button pad.
Dec 16, 2009 | KitchenAid KHHS179LSS Convection /...
Replace door handle on microwave Kitchenaid KHHS179LSS. I have the part.
You will need to access the door handle mounting screws and remove it to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife to carefully insert in the seam and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches. NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 15, 2009 | Microwave Ovens
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
1,418 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
