Question about Olympus WS-100 Digital Voice Recorder
VCVA I'm setting the VCVA to on and setting the recording mode to SP to record longer, but even set on HQ I only get about 20mins of recording before it shuts off. In the directions on page 8 it says; "using the FF and REW buttons, the VCVA level can be adjusted in 15 levels." What levels and where are they? Also I can not get the 'remain' time to show up and I'm following the directions.
  • 44 Answers
Http://resources.olympus-europa.com/consumer/service/C1256F17001FD37E4F1A57B3D91D11D3C1256FF10047E9C7_VCVA.pdf
This link might be helpful to you, if not reply again, provide u more....
best of luck..........
Posted on Feb 10, 2008
I am trying to record a program in EP mode but when it records it returns back to SP mode. How can I set the tape for EP without it returning to SP?
Most VCR's have a default recording setting for recording speed or other settings. It's just a question of finding the right menu. Have a good look around the menus. However the VCR might default to SP after recording in EP, however the playback should switch to EP when playing.
Jun 09, 2010 | Televison & Video
Olympus Voice Recorder says only 6 hours time when it's empty
Hello
The recorder should be formatted only by using the internal FORMAT function found in the Menu. Formatting using the computer may corrupt system files needed to run the recorder and may delete the Voice Guide Data and Audible system files, so computer formatting is not recommended. When the recorder is connected to a computer, individual files can be deleted using My Computer without negative effects.after you format the unit this is how needs t
be depends on your selection for Audio quality
STEREO XQ mode: 17 hours 30 minutes
STEREO HQ mode: 35 hours 10 minutes
HQ mode: 70 hours 20 minutes
SP mode: 138 hours 30 minutes
LP mode: 275 hours 20 minutes
if this don't solved your problem you can get one really cheap athttp://www.tvps.com/Products/Olympus-DS-50-1-GB-Digital-Portable-Voice-Recorder---Demo-DS50__OL-D-DS-50.aspx just like a back up
Feb 10, 2010 | Olympus DS-50 Digital Voice Recorder
I need the instructions manual for olympus pearlcorder j300 microcassette
put in 2 AAA batts and insert a tape, then push record to record, and expirament!
VCVA
set it to VCVA on the left side and push record, will only record when detects noise
Oct 24, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
Why would my ds 4000 loose sections of the recording and then pick back up again.
If you have the VCVA set to on maybe the actuation level set too low; the recorder stops recording when the sound level does't reach that level.
Adjust the level to a higher value.
Here is a link to the DS-4000 Instruction Manual
Aug 09, 2009 | Olympus DS-40 Digital Voice Recorder
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
    Hi all,
    I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
    The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
    To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
    Turn on
    Press 'M' to cycle to 'REC' mode
    Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
    Record as usual.
    I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
    If anyone knows what VOR is then please shout back.
    Hope this helps.
    Liam
    Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
    Limited recording time
    WS-100: 64 MB
    HQ mode: Approx. 4 hours 20 minutes
    SP mode: Approx. 8 hours 40 minutes
    LP mode: Approx. 27 hours 20 minutes
    You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
    Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
    My panasonic dvd recorder seems just to record 1hr and 1 minute of a programme then stops recording. I've tried different discs but it's just the same
    make sure the disc quality is not set to HQ high quality otherwise disc time is shorter than SQ or SP standard quality standard play
    Nov 27, 2008 | Televison & Video
    Setting the tape speed
    Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
    You can not change speed SP/LP during playback mode because its properties of signal set during recording.
    Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
    SP/EP mode?
    This again, is set via the remote, in the on-screen menu.
    Jun 02, 2007 | Samsung VR3607 VHS VCR
    Olympus WS-100 Digital Voice Recorder Logo
    173 people viewed this question
    Top Olympus Audio Players & Recorders Experts
    pankaj rautela
    pankaj rautela
    Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
