Question about HP Compaq ProLiant ML330e Server
Windows 2003 server standard edition
How can I share my internet connections to other workstation. I am using windows 2003 server standard edtion and I am also connected to a router.
  • foamesh May 11, 2010
    what kind of router do you have? Can you purchase an ethernet switch to connect the other workstation?
  • 118 Answers
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Posted on Jan 27, 2008
  • Anonymous Jan 27, 2008
    If the standard additon do not provide routing and remote access , try installing an advanced or enterprise server
6ya staff
SOURCE:
Bloking internet connectivity
You can setup the two switches to be on two different VLANs if they are smart switches and assign the IP's to the sepearte networks via DHCP. you can then block internet for the desired IP range and allow for the other subnet,
Apr 10, 2010 | Microsoft Windows Server 2003 Standard...
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Windows 98 crashes while I am accessing a share from a server
The OS may not be compatible for Server 2003, The best thing that you can do here is to upgrade your operating system to Windows XP or Windows Vista for full compliant on Networking.
Jul 29, 2009 | Microsoft Windows 98 Second Edition OEM...
D-Link DES1008D 8 port fast ethernet desktop switch
By using it, of course you have this items to connect it with internet:
  1. UTP Wire with Connectors at end each PC or Client Workstation.
  2. Make sure every PC or Client Workstation have its own LAN Card.
  3. To connect on the internet is to know what is IP Address, Gateway Address & DNS Server Address settings on your LAN connection.
  4. Lastly, It should have internet provider in your place.
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Internet Sharings
hi
first of all can u plz tell me how do u connect to internet like u use a connectiode or something if yes its very easy u just need to right click on the connectiode & just go to properties click on the advance tab & under the internet connections sharing put the check mark on allow other network user to connect to internet through this computer internet connection thats it. u will be able to access the internet on all the pc on ur network. incase if u still have any problem just let me know & also provide the details on ur network like how u connect, any router hub or switch is been use for connecting pcs etc
Oct 02, 2008 | Computers & Internet
ODBC
give ur add i want to check it out.
Aug 26, 2008 | Microsoft Windows Server Standard 2003 for...
Internet sharing
Hello Sir ''''''''''
>>>>>> u;r using dial up or broad band connection i do't know ok anyway connect u;r internet connection u see Taskbar right side Blink two computer's Dubble click that computers see some Option Below
######### Click Properties Go to Advanced See (internet Connection Sharing) this below -- Allow other network users to connect through this computer's internet connection. one box is thair Click that box right Mark ok byy
Apr 17, 2008 | Microsoft Windows Server Standard 2003 for...
Internet connectio
Vista is 64 bit OS, server 2003 standard is 32 bit. Change Server 2003 to Server 2003 R to get compatible. See Microsoft website. May suggest Server 2008.
Good luck.
Feb 13, 2008 | Microsoft Windows Server 2003 Web Edition...
Open Questions:
See all HP Compaq ProLiant ML330e Server Questions
HP Compaq ProLiant ML330e Server Logo
115 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
