Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
No picture when switched on there is no picture . this only started to happen after a blackout, tried to plug and unplug several times but to no avail?
Posted on Jan 27, 2008
  • 106 Answers
Open the back cover and disconnect the Y - Board Vs plug from the Power Supply board. Check the Vs voltage in Power Supply board when turn on the tv. If the Vs voltage is there, it means the power supply is good and try to replace the Y-Board. Otherwise, try to replace the Power Supply board. If your tv is still in warranty, just let the warranty depot shop fix tv for you.
There can be lots of things in the whole audio chain that can be wrong, but I limit to things you could try and test yourself.
You could switch the sound switch, where it says Hi-Fi Sound several times, up and down and then check if on any setting you hear something. (lift the view finder up. I thought it was the switch to the front.
Then you could try to put in a headphone, and listen if you then hear any sound. If the switch behind the plug is oxidised the sound is gone too. If you hear sound in the headphone you know almost every thing is working. when you unplug the phone and you again hear nothing, plug and unplug several times. Difficult to clean it yourself, because you could cause the oxide or other debris comes in the camera.
Then you have a video / audio output switch right side to the front, try switching that one too, several times. I hope you get the old baby working again.
Jan 17, 2014 | Cameras
Gtvl19w17hdf wont switch on
For a 19 inch set the answer may be retirement---but have you tried to unplug it and or the box if used for signal for a while and plugged back to see if a reboot cures it(set will try if unplugged a while to do this)?
You might also call Goodman's customer service to see if the set has a hard reset done with the remote or even a software/firmware upgrade available.
What have you got to lose by trying?
Apr 11, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I had a blackout in my area that lasted for 5
is this a dedicated machine (original manufactures cabinet) which model do you it the stand up or cocktail table...if its the stand up and you know where the switch is located inside the coin door to enter the diagnostic can go in there and restore the factory settings
let me know if you need further help with this issue
May 11, 2010 | Arcade Ms Pac Man / Galaga Cocktail Table...
F35 error code
W10156252 pressure switch. Remove top of washing machine (remove allen wrench screws in back). Standing in front of machine, the part is attached to the right upper rear side panel. Reach behind the mount point and gently squeeze the plastic mounting snaps together to release the switch. Unplug the rubber tubing from the old switch and gently unplug the wire connector. Plug wire harness into new switch, plug in rubber tubing. Snap new switch back in mount. As of 9/01/09, the switch is only available at Whirlpool. It's ridiculously expensive $112.00. Try to find it cheaper first (lists on some sites for $89.00 but at the time was unavailable). IMPORTANT!!! Use no more than ONE TABLESPOON of "he" detergent. That's right, ONE tablespoon. Too much detergent is why the switch failed.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Switching on by itself
Try covering the little red window that has the wireless remote receiver behind it. See what happens.If the problem quits,your stereo is picking up some other IR source in the room.
Also,shoot some WD40 into the cutout around the power switch
( WITH THE POWER UNPLUGGED) push the switch on/off several times then plug the AC back in.
Jan 07, 2009 | Technics SCEH790 CD Shelf System
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
634 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
