Baumatic 23 in. BDW9 Built-in Dishwasher Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Baumatic bdw9 dishwasher's door is leaking from the bottom, I dont know if it is over filling or the door seals have gone, any help would be appreciated
911 SERVICE TODAY
Level 3:
  • Baumatic Master 528 Answers
  • Posted on Jan 01, 2010
911 SERVICE TODAY
Baumatic Master
Level 3:
Answers
528
Questions
Helped
119097
Points
1127
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Door rope replacement.
Check the old one. Fasten it in the same way to the rope with the correct rope length.
3helpful
My left hand side door cord has broken, how much of the machine do I need to take apart? do I need to pull the machine from under the counter top?
Yes you will have to move from under worktop and then remove the side panel that the cord has broken.It may be worth checking the other cord and replacing both if worn.Also check if something is catching to cause the cord to break.
Hope this helped.
Leaking from bottom of door
thereis a float switch in the pan it is usualy a plastic inverted cup like thing there is an electrical switch connected to this usualy by a plunger it is either out of adjustment the float may be gunked up or the switch is just faulty now
Eurotech Dishwasher is leaking - How to get to the guts to fix it
When a dishwasher leaks, it is usually the door seal or the water level gone wrong. Assuming the door was never leaned-on and the hinges bent, then you look to the seal or in some cases a splashshield fin that goes along the bottom between door and frame. If the unit is more than 7 or 8 years, the seal or shield plate could have lost its shape enough to allow water to get by.
The other problem, is the water level is too hi and this can be because the float switch is filled with soap scum and is heavier than normal, so the float thinks there needs to be more water than usual. Clean the float, you may need to remove a guard shroud to access the float. Goodluck, macgivor
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Baumatic DW9
Hi - You can download the manual by clicking the link underlined in blue below:
Baumatic DW9
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Baumatic dishwasher BDW9
This looks to be the same problem I'm having with my dishwasher (BDW15) I have removed the control panel and have noticed the On Off button has started to burn out, thus cuasing intermitant power supply.
Solution is to replace the On Off switch with a new one, which I'm still drying to source as it's Christmas and everybody is shut.
Hope this helps
Craig...
Dishwasher not draining and 3 lights are flashing
check this thread for starters http://www.fixya.com/support/t135923-dishwasher_beeping the solution to the leak would depend on where you think it is leaking from - usual areas to check are the door seal, door latch, inlet and drain hoses and where they connect, the base especially towards the back. also make sure the drain pipe the dishwasher is connected to is not blocked - sometimes leaks from in the machine can be traced to this cause. Hope this helps, post again if you find anything and hopefully we can help more :)
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
