Question about Fossil AM3726 Wrist Watch
Need To Takeout a Link in Band
SUISSE TECHNIK WATCH I Need to know how to take the pin out to get the link out Please
  • 145 Answers
I know little about this watch, but generally there is an arrow on the inside of the band, you can use a small screwdriver to push on the side, or perhaps in a small hole on the inside of the band to force the link pin/s out in the direction of the arrow.
Posted on Jan 27, 2008
How do you re3move a link from a Casio watch band
take it to a jeweler and they will send it to casio to remove a link. The clip may have movable anchoring points . You need a pin to push in the pins inside the link on both sides. then move the link and re anchor the band under the clip.
Jan 25, 2015 | Casio Mens WV58DA-1AV Waveceptor Atomic...
How do you remove links from a casio watch strap S-1183DV on watch WV-59DU ?
You will need to hold the watch firmly in your hand, with the side pointing up. Make sure that you can grip it firmly. If you have trouble holding onto the watch, place it on a stable surface. Make sure that the side is facing toward the ceiling and locate a connecting pin. There will be a connecting pin on each link of the watch band. Select a link, and hold the eyeleteer over the connecting pin for that link. Carefully place the eyeleteer onto the connecting pin. Push gently but firmly until the connecting pin slides partially out the other side. Occasionally, the pin will be difficult to push through the slot. If this is the case, gently tap it though with a standard hammer. Using a pair of pliers, pull on the connecting pin carefully until it slides out. Keep a firm grip on the watch band so that the links do not come apart before you are ready for them to. Separate the Casio watch band. Repeat this process with additional links until the watch band is as small as you would like it to be. Reconnect the band by tapping or pushing a connecting pin into the band where it is disconnected.
Aug 06, 2011 | Casio Watches
How do i know its a genuine watch has on the rear
where can i find a watch band for the bvlgari model al 38a l 3276?
Jul 29, 2011 | Bvlgari Aluminium White Dial Solid Black...
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Aug 14, 2010 | Citizen Watches
Is there any way to adjust the band without a special tool?
Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
Make sure to examine the watch and which links have pins. Some watches are designed to have a row of removable links with pins.
Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
You may need to use something a little stout like a butterknife to tap the pins out from the links.
The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
Oct 04, 2009 | Festina 16177 3 Watch
10L02 Wittnauer watch~need band screws that connect link to link
If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
Jul 18, 2009 | Watches
How do i use the watch band link tool i just got with no instruct
Rolex is using screws instead of pins. Get the small screwdriver and unscrew the bracelet screws.
Do not forget to rate, please.
Feb 11, 2009 | Rolex Datejust SS
Want to fit a watch band. take links out.
You need a link tool. You can purchase this item on Ebay or watch parts sites. Some have a little track that you put the band on and screw a pin into the pin on the band and it pushes the split pin out and you remove the link. Pay attention to the pins on the band. You need to push out the side with the split pin that looks like a flathead screw. It sometimes is. In most cases it is a pin. When the link is removed you have to connect to the next link and push the pin into the hole again and it shoul go in the direction of the other pins. The pin should go in on the side with the split looking pins. You will need special tools: pin pusher device, a pin block and hammer with pins to hammer out the pins on the band usually. Some or most folks take classes to learn this but you may be handy and figure it out.
Dec 03, 2008 | Invicta Watches
Fossil AM3726 Wrist Watch Logo
178 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
