posted by climberboy on Jan 27, 2008
Just recently my Bosch aluminum dough hook had a black/grey substance start rubbing off of it. I have been washing it in the dishwasher and didn't know if that was causing some problem. Is it still safe to use?
1 Other User Has The Same Problem
Comment by terylray, posted on Feb 16, 2008
My Bosch is doing the same thing, but it is all the matte-colored grey metal parts. They are leaving grey smudges that are rubbing off on my hands. Also, there are small white bumps or dots appearing on the metal surface. I need to know if this is safe for my family to continue to eat from.
Best Solution
posted on Jan 28, 2008
the problem is where the pin on the beater shaft locks into the hook may be wearing down or the hook itself.when you put the hook on see if you get alot of play in the hook (wiggle it and if it feels really loose its worn).its still safe to use but eventually (and this may be quite sometime) the pin may break off the beater shaft.you would then have to replace the pin and hook.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch 700 Watts MUM6622 Universal
Email this problem
Email this problem
Can you Help with these Mixers problems?
Bosch 700 Watts MUM6622 Universal Series...
aluminum bowl and dough hook
the screw that attaches the... Answer This...
bosch universal does not mix...
Hi, I have a Bosch Universal... Answer This...
Universal Bosch mixer quit and...
I have a universal bosch mixer... Answer This...
Repair Service
Find Mixer Repairman Near You:
Find Parts
